Ana içeriğe geç
Asus Chromebook C523N Keyboard Replacement
Neye ihtiyacın var
    1. Asus Chromebook C523N Keyboard Replacement, Back Cover: adım 1, 2 resimden 1. Asus Chromebook C523N Keyboard Replacement, Back Cover: adım 1, 2 resimden 2.
      • Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
      • Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Chromebook C523N Keyboard Replacement: adım 2, 2 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 2, 2 resimden 2.
      • Using a spudger, lift the top left base pad and remove it to reveal a final screw underneath.
      • Remove the one 0.5mm JIS #00 screw underneath the base pad.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Chromebook C523N Keyboard Replacement: adım 3, 2 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 3, 2 resimden 2.
      • Use an opening tool to gently pry the base enclosure up and remove from the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. Asus Chromebook C523N Keyboard Replacement, Speaker: adım 4, 3 resimden 1. Asus Chromebook C523N Keyboard Replacement, Speaker: adım 4, 3 resimden 2. Asus Chromebook C523N Keyboard Replacement, Speaker: adım 4, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Using the nylon tipped tweezers, gently pry the black and white wires from the wireless card and lift.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Chromebook C523N Keyboard Replacement: adım 5, 3 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 5, 3 resimden 2. Asus Chromebook C523N Keyboard Replacement: adım 5, 3 resimden 3.
      • Use a spudger to pry the small tangle of black, red, white, and blue wires from the audio connector, pushing the wires back toward the speaker.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Chromebook C523N Keyboard Replacement: adım 6, 2 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 6, 2 resimden 2.
      • Use a spudger to pry the black wire from the audio connector, pushing the wires back toward the left speaker.
      FixBot'a Sor
      Yorum Ekle
    4. Asus Chromebook C523N Keyboard Replacement: adım 7, 1 resimden 1.
      • Gently grab both speakers and lift them from the Chromebook to remove.
      FixBot'a Sor
      Yorum Ekle
    1. Asus Chromebook C523N Keyboard Replacement, Battery: adım 8, 3 resimden 1. Asus Chromebook C523N Keyboard Replacement, Battery: adım 8, 3 resimden 2. Asus Chromebook C523N Keyboard Replacement, Battery: adım 8, 3 resimden 3.
      • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small locking flap.
      • Gently disconnect the battery cable from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Chromebook C523N Keyboard Replacement: adım 9, 2 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 9, 2 resimden 2.
      • Remove six 1.4 mm JIS #00 screws from the battery.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Chromebook C523N Keyboard Replacement: adım 10, 1 resimden 1.
      • Remove the battery from the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. Asus Chromebook C523N Keyboard Replacement, Motherboard: adım 11, 3 resimden 1. Asus Chromebook C523N Keyboard Replacement, Motherboard: adım 11, 3 resimden 2. Asus Chromebook C523N Keyboard Replacement, Motherboard: adım 11, 3 resimden 3.
      • Using tweezers, gently pry the black and white wires from the wireless card and lift.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Chromebook C523N Keyboard Replacement: adım 12, 3 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 12, 3 resimden 2. Asus Chromebook C523N Keyboard Replacement: adım 12, 3 resimden 3.
      • Gently pull the trackpad cable from the connector, located next to the wireless card.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Chromebook C523N Keyboard Replacement: adım 13, 3 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 13, 3 resimden 2. Asus Chromebook C523N Keyboard Replacement: adım 13, 3 resimden 3.
      • Using a spudger, disconnect the two side-by-side ribbon cables from their connectors, pushing in the direction of the ribbons (toward the left side of the Chromebook).
      FixBot'a Sor
      Yorum Ekle
    4. Asus Chromebook C523N Keyboard Replacement: adım 14, 2 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 14, 2 resimden 2.
      • Disconnect the thick blue ribbon cable from the connector by pulling it away from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    5. Asus Chromebook C523N Keyboard Replacement: adım 15, 3 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 15, 3 resimden 2. Asus Chromebook C523N Keyboard Replacement: adım 15, 3 resimden 3.
      • Remove the 0.4mm JIS #0 screws from the heat sink in the center of the motherboard.
      • Lift and remove the heat sink.
      FixBot'a Sor
      Yorum Ekle
    6. Asus Chromebook C523N Keyboard Replacement: adım 16, 3 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 16, 3 resimden 2. Asus Chromebook C523N Keyboard Replacement: adım 16, 3 resimden 3.
      • Gripping the thin white ribbon cable, gently pull it away from the motherboard to disconnect.
      FixBot'a Sor
      Yorum Ekle
    7. Asus Chromebook C523N Keyboard Replacement: adım 17, 2 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 17, 2 resimden 2.
      • Disconnect the thick black connector by gently pulling it up, away from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    8. Asus Chromebook C523N Keyboard Replacement: adım 18, 2 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 18, 2 resimden 2.
      • Remove the two 0.4mm JIS #00 screws at the bottom of the hinge (closest to the motherboard).
      • Using an opening tool, pry the hinge upward.
      FixBot'a Sor
      Yorum Ekle
    9. Asus Chromebook C523N Keyboard Replacement: adım 19, 2 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 19, 2 resimden 2.
      • Remove the two 0.4 mm JIS #00 screws from the motherboard.
      • Gently lift and remove the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. Asus Chromebook C523N Keyboard Replacement, Touchpad: adım 20, 1 resimden 1.
      • Pull gently on the touchpad cable connector to disconnect.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Chromebook C523N Keyboard Replacement: adım 21, 1 resimden 1.
      • Carefully, remove the tape from the touch pad only.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Chromebook C523N Keyboard Replacement: adım 22, 1 resimden 1.
      • Remove the three 1.4 mm JIS #00 screws.
      FixBot'a Sor
      Yorum Ekle
    4. Asus Chromebook C523N Keyboard Replacement: adım 23, 2 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 23, 2 resimden 2.
      • Lift at the far edge of the touchpad to remove it.
      FixBot'a Sor
      Yorum Ekle
    1. Asus Chromebook C523N Keyboard Replacement, Keyboard: adım 24, 2 resimden 1. Asus Chromebook C523N Keyboard Replacement, Keyboard: adım 24, 2 resimden 2.
      • Disconnect the two ribbon cables from the daughterboard.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Chromebook C523N Keyboard Replacement: adım 25, 1 resimden 1.
      • Remove the four 0.4mm JIS #00 screws from the daughterboard.
      • Remove the daughterboard.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Chromebook C523N Keyboard Replacement: adım 26, 1 resimden 1.
      • Remove the two 0.4mm JIS #00 screws on the left hinge.
      FixBot'a Sor
      Yorum Ekle
    4. Asus Chromebook C523N Keyboard Replacement: adım 27, 1 resimden 1.
      • Lift the keyboard of the Chromebook off of the screen.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
Great walk through. I used this to replace a keyboard on a C423N ASUS. Everything but the track pad connector on the mother board and three screws instead of 2 on the screen hinges is the same.
Charles Stanley - Yanıt Paylaş
Hi there
How would I replace the screen for this model??
Saif - Yanıt Paylaş
how to replace ssd in motherbord
Suresh dhakar - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 36
Her zaman: 2,914
