Ana içeriğe geç
Asus Chromebook C523N Keyboard Replacement
Neye ihtiyacın var
  1. Asus Chromebook C523N Keyboard Replacement, Back Cover: adım 1, 2 resimden 1. Asus Chromebook C523N Keyboard Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
    • Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
  2. Asus Chromebook C523N Keyboard Replacement: adım 2, 2 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 2, 2 resimden 2.
    • Using a spudger, lift the top left base pad and remove it to reveal a final screw underneath.
    • Remove the one 0.5mm JIS #00 screw underneath the base pad.
  3. Asus Chromebook C523N Keyboard Replacement: adım 3, 2 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 3, 2 resimden 2.
    • Use an opening tool to gently pry the base enclosure up and remove from the laptop.
  4. Asus Chromebook C523N Keyboard Replacement, Speaker: adım 4, 3 resimden 1. Asus Chromebook C523N Keyboard Replacement, Speaker: adım 4, 3 resimden 2. Asus Chromebook C523N Keyboard Replacement, Speaker: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using the nylon tipped tweezers, gently pry the black and white wires from the wireless card and lift.
  5. Asus Chromebook C523N Keyboard Replacement: adım 5, 3 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 5, 3 resimden 2. Asus Chromebook C523N Keyboard Replacement: adım 5, 3 resimden 3.
    • Use a spudger to pry the small tangle of black, red, white, and blue wires from the audio connector, pushing the wires back toward the speaker.
  6. Asus Chromebook C523N Keyboard Replacement: adım 6, 2 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 6, 2 resimden 2.
    • Use a spudger to pry the black wire from the audio connector, pushing the wires back toward the left speaker.
  7. Asus Chromebook C523N Keyboard Replacement: adım 7, 1 resimden 1.
    • Gently grab both speakers and lift them from the Chromebook to remove.
  8. Asus Chromebook C523N Keyboard Replacement, Battery: adım 8, 3 resimden 1. Asus Chromebook C523N Keyboard Replacement, Battery: adım 8, 3 resimden 2. Asus Chromebook C523N Keyboard Replacement, Battery: adım 8, 3 resimden 3.
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small locking flap.
    • Gently disconnect the battery cable from the motherboard.
  9. Asus Chromebook C523N Keyboard Replacement: adım 9, 2 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 9, 2 resimden 2.
    • Remove six 1.4 mm JIS #00 screws from the battery.
  10. Asus Chromebook C523N Keyboard Replacement: adım 10, 1 resimden 1.
    • Remove the battery from the laptop.
  11. Asus Chromebook C523N Keyboard Replacement, Motherboard: adım 11, 3 resimden 1. Asus Chromebook C523N Keyboard Replacement, Motherboard: adım 11, 3 resimden 2. Asus Chromebook C523N Keyboard Replacement, Motherboard: adım 11, 3 resimden 3.
    Satın Al
    • Using tweezers, gently pry the black and white wires from the wireless card and lift.
  12. Asus Chromebook C523N Keyboard Replacement: adım 12, 3 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 12, 3 resimden 2. Asus Chromebook C523N Keyboard Replacement: adım 12, 3 resimden 3.
    • Gently pull the trackpad cable from the connector, located next to the wireless card.
  13. Asus Chromebook C523N Keyboard Replacement: adım 13, 3 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 13, 3 resimden 2. Asus Chromebook C523N Keyboard Replacement: adım 13, 3 resimden 3.
    • Using a spudger, disconnect the two side-by-side ribbon cables from their connectors, pushing in the direction of the ribbons (toward the left side of the Chromebook).
  14. Asus Chromebook C523N Keyboard Replacement: adım 14, 2 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 14, 2 resimden 2.
    • Disconnect the thick blue ribbon cable from the connector by pulling it away from the motherboard.
  15. Asus Chromebook C523N Keyboard Replacement: adım 15, 3 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 15, 3 resimden 2. Asus Chromebook C523N Keyboard Replacement: adım 15, 3 resimden 3.
    • Remove the 0.4mm JIS #0 screws from the heat sink in the center of the motherboard.
    • Lift and remove the heat sink.
  16. Asus Chromebook C523N Keyboard Replacement: adım 16, 3 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 16, 3 resimden 2. Asus Chromebook C523N Keyboard Replacement: adım 16, 3 resimden 3.
    • Gripping the thin white ribbon cable, gently pull it away from the motherboard to disconnect.
  17. Asus Chromebook C523N Keyboard Replacement: adım 17, 2 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 17, 2 resimden 2.
    • Disconnect the thick black connector by gently pulling it up, away from the motherboard.
  18. Asus Chromebook C523N Keyboard Replacement: adım 18, 2 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 18, 2 resimden 2.
    • Remove the two 0.4mm JIS #00 screws at the bottom of the hinge (closest to the motherboard).
    • Using an opening tool, pry the hinge upward.
  19. Asus Chromebook C523N Keyboard Replacement: adım 19, 2 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 19, 2 resimden 2.
    • Remove the two 0.4 mm JIS #00 screws from the motherboard.
    • Gently lift and remove the motherboard.
  20. Asus Chromebook C523N Keyboard Replacement, Touchpad: adım 20, 1 resimden 1.
    • Pull gently on the touchpad cable connector to disconnect.
  21. Asus Chromebook C523N Keyboard Replacement: adım 21, 1 resimden 1.
    • Carefully, remove the tape from the touch pad only.
  22. Asus Chromebook C523N Keyboard Replacement: adım 22, 1 resimden 1.
    • Remove the three 1.4 mm JIS #00 screws.
  23. Asus Chromebook C523N Keyboard Replacement: adım 23, 2 resimden 1. Asus Chromebook C523N Keyboard Replacement: adım 23, 2 resimden 2.
    • Lift at the far edge of the touchpad to remove it.
  24. Asus Chromebook C523N Keyboard Replacement, Keyboard: adım 24, 2 resimden 1. Asus Chromebook C523N Keyboard Replacement, Keyboard: adım 24, 2 resimden 2.
    • Disconnect the two ribbon cables from the daughterboard.
  25. Asus Chromebook C523N Keyboard Replacement: adım 25, 1 resimden 1.
    • Remove the four 0.4mm JIS #00 screws from the daughterboard.
    • Remove the daughterboard.
  26. Asus Chromebook C523N Keyboard Replacement: adım 26, 1 resimden 1.
    • Remove the two 0.4mm JIS #00 screws on the left hinge.
  27. Asus Chromebook C523N Keyboard Replacement: adım 27, 1 resimden 1.
    • Lift the keyboard of the Chromebook off of the screen.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Great walk through. I used this to replace a keyboard on a C423N ASUS. Everything but the track pad connector on the mother board and three screws instead of 2 on the screen hinges is the same.
Charles Stanley - Yanıt
Hi there
How would I replace the screen for this model??
Saif - Yanıt
how to replace ssd in motherbord
Suresh dhakar - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 23
Her zaman: 2,230
