Ana içeriğe geç
Asus Chromebook C523N Touchpad Replacement
Neye ihtiyacın var
  1. Asus Chromebook C523N Touchpad Replacement, Back Cover: adım 1, 2 resimden 1. Asus Chromebook C523N Touchpad Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
    • Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
  2. Asus Chromebook C523N Touchpad Replacement: adım 2, 2 resimden 1. Asus Chromebook C523N Touchpad Replacement: adım 2, 2 resimden 2.
    • Using a spudger, lift the top left base pad and remove it to reveal a final screw underneath.
    • Remove the one 0.5mm JIS #00 screw underneath the base pad.
  3. Asus Chromebook C523N Touchpad Replacement: adım 3, 2 resimden 1. Asus Chromebook C523N Touchpad Replacement: adım 3, 2 resimden 2.
    • Use an opening tool to gently pry the base enclosure up and remove from the laptop.
  4. Asus Chromebook C523N Touchpad Replacement, Battery: adım 4, 3 resimden 1. Asus Chromebook C523N Touchpad Replacement, Battery: adım 4, 3 resimden 2. Asus Chromebook C523N Touchpad Replacement, Battery: adım 4, 3 resimden 3.
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small locking flap.
    • Gently disconnect the battery cable from the motherboard.
  5. Asus Chromebook C523N Touchpad Replacement: adım 5, 2 resimden 1. Asus Chromebook C523N Touchpad Replacement: adım 5, 2 resimden 2.
    • Remove six 1.4 mm JIS #00 screws from the battery.
  6. Asus Chromebook C523N Touchpad Replacement: adım 6, 1 resimden 1.
    • Remove the battery from the laptop.
  7. Asus Chromebook C523N Touchpad Replacement, Touchpad: adım 7, 1 resimden 1.
    • Pull gently on the touchpad cable connector to disconnect.
  8. Asus Chromebook C523N Touchpad Replacement: adım 8, 1 resimden 1.
    • Carefully, remove the tape from the touch pad only.
  9. Asus Chromebook C523N Touchpad Replacement: adım 9, 1 resimden 1.
    • Remove the three 1.4 mm JIS #00 screws.
  10. Asus Chromebook C523N Touchpad Replacement: adım 10, 2 resimden 1. Asus Chromebook C523N Touchpad Replacement: adım 10, 2 resimden 2.
    • Lift at the far edge of the touchpad to remove it.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
3 Yorum
Where do i buy the replacement touch pad
Anthony hughs - Yanıt
Very precise and clear. Thank you.
Raymond Trail - Yanıt
very clear instructions and photos. It was Easy, as described! One repairer had advised I buy a new Chromebook, bought an unused touchpad for £11. It took me a bit longer than the estimated 15 minutes, but this was the first time I’ve ever had the back off a laptop and attempted a repair/replacement, so took loads of photo’s on the way and took my time. I’ll definitely consider another DIY repair in the future.
John Outhwaite - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 889
