Ana içeriğe geç
Asus Chromebook Flip C100 Lower Case Replacement
Neye ihtiyacın var
  1. Asus Chromebook Flip C100 Lower Case Replacement, Lower Case: adım 1, 1 resimden 1.
    • Unscrew the eight bottom cover screws (one of them is under the hand) using a screwdriver with a J1000 tip.
    • Unscrew the middle screw towards the top of the device using a screwdriver with a T5 tip.
  2. Asus Chromebook Flip C100 Lower Case Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool to remove the four bottom rubber feet.
  3. Asus Chromebook Flip C100 Lower Case Replacement: adım 3, 1 resimden 1.
    • Unscrew the four screws under the feet using a screwdriver with a J100 tip.
  4. Asus Chromebook Flip C100 Lower Case Replacement: adım 4, 1 resimden 1.
    • Use the plastic opening tool to pry up the palm rest assembly.
  5. Asus Chromebook Flip C100 Lower Case Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Disconnect the two cables from the motherboard with tweezers
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
great guide, though i found the nine screws on the outside required a t5 tip, while the 5 under the feet looked like they were either j100 or j1000, but a philips head worked.
Matthew Sylvester - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 5,137
