Giriş
In this replacement guide, you will be instructed on the process of removing the back plate, making sure the laptop is turned off and not connected to a power source and removing the necessary components are removed so that the charging port can be removed and eventually replaced.
Neye ihtiyacın var
Remove three of the rubber feet on the bottom cover with a plastic or metal spudger.
10 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I just did this but now when I turn it on there is no picture on the computer. I had to change the charging port because my cats knocked over a water glass. The charging port was successful because the light was on. Amy troubleshooting?
