Ana içeriğe geç
Asus Chromebook Flip C100P Power and Volume Buttons Replacement
Neye ihtiyacın var
  1. Asus Chromebook Flip C100P Power and Volume Buttons Replacement, Power and Volume Buttons: adım 1, 1 resimden 1.
    • Remove three of the rubber feet on the bottom cover with a plastic or metal spudger.
  2. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: adım 2, 1 resimden 1.
    • Remove the five screws from beneath the rubber feet using a philips head screwdriver. The first 1.9mm screw is located under the front right foot, the second 1.9mm screw and third 2.3mm screw are located under the rear right foot, and the fourth and fifth 2.3mm screws are located under the rear left foot.
  3. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: adım 3, 1 resimden 1.
    • Remove the eight 3mm bottom cover screws and one 6mm screw using a T5 screwdriver. Set apart the screw in the rear middle of the bottom cover from the the other eight screws, as it is longer than them.
  4. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: adım 4, 3 resimden 1. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: adım 4, 3 resimden 2. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: adım 4, 3 resimden 3.
    • Pry the palm rest assembly apart from the bottom cover using a spudger. This step may require a bit of elbow grease. Once the palm rest has been separated from the bottom cover, pull it away from the screen, rather than away from yourself.
  5. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: adım 5, 3 resimden 1. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: adım 5, 3 resimden 2. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: adım 5, 3 resimden 3.
    • Disconnect the touchpad cable and the keyboard cable on the palm rest assembly from the motherboard using the pointed end of a plastic spudger.
  6. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: adım 6, 2 resimden 1. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: adım 6, 2 resimden 2.
    • Flip up the white part of the connector using the pointed end of a plastic spudge.
  7. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: adım 7, 1 resimden 1.
    • Pull the cable out by the blue tab.
  8. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: adım 8, 1 resimden 1.
    • Unscrew two 2.7 mm screws using the Phillips #0 screwdriver.
  9. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: adım 9, 1 resimden 1.
    • Remove the button chip.
  10. Asus Chromebook Flip C100P Power and Volume Buttons Replacement: adım 10, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, carefully pull out the external buttons.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew Thomson
181 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team S5-G2, Williams Spring 2018 Baylor, Team S5-G2, Williams Spring 2018 üyesi
BU-WILLIAMS-S18S5G2
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 809
