Ana içeriğe geç
Asus Chromebook Flip C302CA Display Replacement
Neye ihtiyacın var
  1. Asus Chromebook Flip C302CA Display Replacement, Back Panel: adım 1, 1 resimden 1.
    • Turn the laptop over so the bottom is facing you.
  2. Asus Chromebook Flip C302CA Display Replacement: adım 2, 3 resimden 1. Asus Chromebook Flip C302CA Display Replacement: adım 2, 3 resimden 2. Asus Chromebook Flip C302CA Display Replacement: adım 2, 3 resimden 3.
    • Remove two rubber caps on the top.
    • Remove the two 1 mm screws using the Phillips #00 screwdriver.
  3. Asus Chromebook Flip C302CA Display Replacement: adım 3, 3 resimden 1. Asus Chromebook Flip C302CA Display Replacement: adım 3, 3 resimden 2. Asus Chromebook Flip C302CA Display Replacement: adım 3, 3 resimden 3.
    • Remove the ten 2 mm screws from the back panel using a T5 Torx screwdriver.
    • Carefully remove the back panel using an opening pick.
  4. Asus Chromebook Flip C302CA Display Replacement: adım 4, 2 resimden 1. Asus Chromebook Flip C302CA Display Replacement: adım 4, 2 resimden 2.
    • Remove the back panel from the laptop.
  5. Asus Chromebook Flip C302CA Display Replacement, Display: adım 5, 1 resimden 1.
    • Remove the black display ports from the motherboard.
  6. Asus Chromebook Flip C302CA Display Replacement: adım 6, 1 resimden 1.
    • Remove the six 2.54 mm Phillips screws from the left and right screen hinge brackets.
  7. Asus Chromebook Flip C302CA Display Replacement: adım 7, 1 resimden 1.
    • Remove the display unit.
  8. Asus Chromebook Flip C302CA Display Replacement: adım 8, 1 resimden 1.
    • Use heat gun to loosen up adhesive on rubber covers for screw.
  9. Asus Chromebook Flip C302CA Display Replacement: adım 9, 1 resimden 1.
    • Remove rubber covers.
  10. Asus Chromebook Flip C302CA Display Replacement: adım 10, 1 resimden 1.
    • Remove the two 2.5 mm screws.
  11. Asus Chromebook Flip C302CA Display Replacement: adım 11, 1 resimden 1.
    • Use prying tool to separate panel from monitor.
  12. Asus Chromebook Flip C302CA Display Replacement: adım 12, 1 resimden 1.
    • Remove this connection by pulling to separate it from the monitor.
  13. Asus Chromebook Flip C302CA Display Replacement: adım 13, 1 resimden 1.
    • Remove connection point and the entire camera assembly including wires.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 18
Her zaman: 373
