Ana içeriğe geç
Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement
  1. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement, Keyboard & Touchpad Assembly: adım 1, 1 resimden 1.
    • Remove the ten 5 mm silver screws on the back panel.
    • Remove the back panel.
  2. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: adım 2, 1 resimden 1.
    • Remove the black wire connected to the audio card.
    • Remove the white wire connected to the audio card.
  3. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: adım 3, 1 resimden 1.
    • Remove the four 2.54 mm black screws connected to the battery and the speakers.
    • Take the battery out of the laptop
  4. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: adım 4, 1 resimden 1.
    • Remove the black strips that connect to the display.
  5. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: adım 5, 1 resimden 1.
    • Pry open the white gate, then disconnect the blue strip.
  6. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: adım 6, 1 resimden 1.
    • Pry open the black gate and then disconnect the blue strip.
  7. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: adım 7, 1 resimden 1.
    • Pry open the black gate, then disconnect the brown strip.
  8. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: adım 8, 1 resimden 1.
    • Remove the two silver screws located in the middle of the motherboard that hold down the copper heatsink.
    • Remove the heatsink from the motherboard.
  9. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: adım 9, 1 resimden 1.
    • Remove the eleven 2.5 mm screws from motherboard/daughterboard.
    • Remove the four 1.3 mm silver screws from the bottom of mother/daughterboard.
    • Remove the motherboard and daughterboard.
  10. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: adım 10, 1 resimden 1.
    • Remove the six 2.5 mm black display screws.
  11. Asus Chromebook Flip C302CA Keyboard & Touchpad Assembly Replacement: adım 11, 1 resimden 1.
    • Remove the two 2.5 mm screws that secure the speakers.
    • Remove the speakers.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 22
Her zaman: 169
