Ana içeriğe geç
Asus Chromebook Flip C302CA Mother & Daughterboard Replacement
Neye ihtiyacın var
  1. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement, Mother & Daughterboard: adım 1, 1 resimden 1.
    • With the T5 Torx Screwdriver, remove the ten 5 mm screws from the back panel.
    • Remove the rubber caps at the top of the panel. Then, using the Phillips #00 Screwdriver, remove the two 1 mm screws underneath.
    • Lift up the back panel.
  2. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Using Tweezers, carefully remove the black wire connected to the audio card.
    • Repeat this process for the white wire.
  3. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: adım 3, 1 resimden 1.
    • Remove the four 2.5 mm screws securing the battery
    • Remove the connector from the motherboard by pulling straight up on it.
    • Carefully lift the battery out of the laptop.
  4. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: adım 4, 1 resimden 1.
    • Remove the highlighted strips connected to the top of the display.
  5. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: adım 5, 1 resimden 1.
    • Gently lift the white tab highlighted in the image. Then, disconnect the blue connector by pulling away from the motherboard.
  6. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: adım 6, 1 resimden 1.
    • Gently lift the black tab highlighted in the photo. Then, repeat the same process mentioned above.
  7. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: adım 7, 1 resimden 1.
    • Once again, lift the white tab highlighted in the image. Then, pull the brown connector away to disconnect it from the motherboard.
  8. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: adım 8, 1 resimden 1.
    • With the Phillips #00 Screwdriver, remove the two highlighted 1 mm screws attaching the heatsink (highlighted in orange) to the motherboard.
    • Then, remove the heatsink from the motherboard.
  9. Asus Chromebook Flip C302CA Mother & Daughterboard Replacement: adım 9, 1 resimden 1.
    • With the Philips-Head #00 Screwdriver, remove the eleven 2.5 mm screws that secure the motherboard.
    • With the same tool, remove the four 1.3 mm screws at the bottom of the mother board/daughterboard.
    • Replace the motherboard/daughterboard.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 165
