Ana içeriğe geç
Asus Eee PC 1000HA RAM Replacement
Neye ihtiyacın var
  1. Asus Eee PC 1000HA RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Remove the battery before working on your device. See this LINK for a step-by-step guide.
    • Gently turn the laptop up side down so that the battery is facing away from you. The battery is outlined by the red rectangle in the picture to the left.
  2. Asus Eee PC 1000HA RAM Replacement: adım 2, 1 resimden 1.
    • Use a #00 Phillips Head screw driver to remove the two 1/4" screws that hold the back panel in place.
  3. Asus Eee PC 1000HA RAM Replacement: adım 3, 1 resimden 1.
    • Place the blue plastic 1/4" opening tool into the small indention and gently pry the back panel off.
  4. Asus Eee PC 1000HA RAM Replacement: adım 4, 1 resimden 1.
    • Remove the back panel.
    • The RAM is shown by the orange marker.
  5. Asus Eee PC 1000HA RAM Replacement: adım 5, 3 resimden 1. Asus Eee PC 1000HA RAM Replacement: adım 5, 3 resimden 2. Asus Eee PC 1000HA RAM Replacement: adım 5, 3 resimden 3.
    • Push the two silver tabs outwards and the RAM will pop up to be removed.
  6. Asus Eee PC 1000HA RAM Replacement: adım 6, 2 resimden 1. Asus Eee PC 1000HA RAM Replacement: adım 6, 2 resimden 2.
    • Gently pull the RAM outwards to remove.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ashlee Stickle
675 İtibar
5 adet Kılavuz yazıldı
Ekip
Sam Houston State, Team 1-1, Blackburne Fall 2015 Sam Houston State, Team 1-1, Blackburne Fall 2015 üyesi
SHSU-BLACKBURNE-F15S1G1
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 462
