Giriş
If you are having problems with the RAM on your device, this guide will help you replace it.
Neye ihtiyacın var
Lay the laptop down with the bottom facing upwards.
Locate the two battery lock slide tabs.
Use a PH00 (+) phillips head to unscrew the two 7 mm screws holding down the back panel.
Use the spudger to pry off the back cover.
2 farklı kişi bu kılavuzu tamamladı.
