Ana içeriğe geç
Asus Eee PC 1005HA Fan Replacement
Neye ihtiyacın var
  1. Asus Eee PC 1005HA Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Lay the laptop upside down.
    • Locate the two battery lock tabs.
  2. Asus Eee PC 1005HA Fan Replacement: adım 2, 3 resimden 1. Asus Eee PC 1005HA Fan Replacement: adım 2, 3 resimden 2. Asus Eee PC 1005HA Fan Replacement: adım 2, 3 resimden 3.
    • Slide the tabs outward to unlock the battery.
    • The left tab will remain unlocked, while the right tab must be held.
    • Holding the right tab open, slide the battery out of the laptop.
  3. Asus Eee PC 1005HA Fan Replacement, Keyboard: adım 3, 2 resimden 1. Asus Eee PC 1005HA Fan Replacement, Keyboard: adım 3, 2 resimden 2.
    • Use a plastic opening tool to pull up the four metal latches in the battery cavity that is located on the bottom of the laptop.
    • Do not apply too much pressure. The latches can not be removed and will bend if forced.
  4. Asus Eee PC 1005HA Fan Replacement: adım 4, 3 resimden 1. Asus Eee PC 1005HA Fan Replacement: adım 4, 3 resimden 2. Asus Eee PC 1005HA Fan Replacement: adım 4, 3 resimden 3.
    • Flip the laptop over, and open the display.
    • Use a plastic opening tool to lift the edge of the keyboard that is nearest to the screen.
    • Gently lift the keyboard and slide it toward the screen.
    • Do not remove the keyboard completely. This can damage the ribbon cable connecting the underside of the keyboard to the laptop.
  5. Asus Eee PC 1005HA Fan Replacement: adım 5, 1 resimden 1.
    • Use a spudger tool to release the tabs on the ribbon cable ZIF connector that is attached to the underside of the keyboard.
    • Depending on the model, the tabs on this ZIF connector will either flip up toward the display or push out toward the display.
    • Once the ZIF connector tabs have been released, remove the keyboard.
  6. Asus Eee PC 1005HA Fan Replacement, Fan: adım 6, 2 resimden 1. Asus Eee PC 1005HA Fan Replacement, Fan: adım 6, 2 resimden 2.
    • Detach the ribbon cable that connects the SD card module and the motherboard by lifting the black clips using the plastic opening tool.
  7. Asus Eee PC 1005HA Fan Replacement: adım 7, 2 resimden 1. Asus Eee PC 1005HA Fan Replacement: adım 7, 2 resimden 2.
    • Detach the Bluetooth wire located below the fan by gently pulling it upward.
  8. Asus Eee PC 1005HA Fan Replacement: adım 8, 2 resimden 1. Asus Eee PC 1005HA Fan Replacement: adım 8, 2 resimden 2.
    • Detach the black structure connected to the input cables in the top right center of the motherboard by pulling them to the right, away from the fan.
  9. Asus Eee PC 1005HA Fan Replacement: adım 9, 2 resimden 1. Asus Eee PC 1005HA Fan Replacement: adım 9, 2 resimden 2.
    • Remove the three 5.5 mm screws holding the motherboard to the motherboard plastic frame.
    • Remove the four 5.5 mm screws surrounding the fan.
  10. Asus Eee PC 1005HA Fan Replacement: adım 10, 1 resimden 1.
    • Gently lift the motherboard and hold it so that the bottom of the board is exposed.
  11. Asus Eee PC 1005HA Fan Replacement: adım 11, 2 resimden 1. Asus Eee PC 1005HA Fan Replacement: adım 11, 2 resimden 2.
    • Disconnect the cable attaching the motherboard to the fan.
  12. Asus Eee PC 1005HA Fan Replacement: adım 12, 3 resimden 1. Asus Eee PC 1005HA Fan Replacement: adım 12, 3 resimden 2. Asus Eee PC 1005HA Fan Replacement: adım 12, 3 resimden 3.
    • Remove two 5.5 mm screws holding the fan and the brass frame to the motherboard.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Maged Hanna
666 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 41
Her zaman: 12,207
