Ana içeriğe geç
Asus Eee PC 1005PEB Battery Replacement
  1. Asus Eee PC 1005PEB Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Start by placing the laptop upside-down on a flat surface.
    • Find the two clips on the back portion of the laptop.
    FixBot'a Sor
    Yorum Ekle
  2. Asus Eee PC 1005PEB Battery Replacement: adım 2, 1 resimden 1.
    • Using your finger, push the clip labeled with a "1" on the laptop from the lock position to unlock position.
    • This clip will hold itself, so after you move it to the unlock position you can remove your finger.
    FixBot'a Sor
    Yorum Ekle
  3. Asus Eee PC 1005PEB Battery Replacement: adım 3, 2 resimden 1. Asus Eee PC 1005PEB Battery Replacement: adım 3, 2 resimden 2.
    • Using your finger, push and hold the pin indicated by a "2" on the laptop from the lock to unlock position.
    • While holding this pin in the unlock position, use your other hand to pull the battery horizontally away from the laptop.
    • When the pins on the battery that reach towards the laptop are away from the laptop, you can release the "2" clip.
    FixBot'a Sor
    Yorum Ekle
  4. Asus Eee PC 1005PEB Battery Replacement: adım 4, 1 resimden 1.
    • Using both hands, pull the battery horizontally away from the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Aaron Arenas
751 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-32, Maness Spring 2014 Cal Poly, Team 13-32, Maness Spring 2014 üyesi
CPSU-MANESS-S14S13G32
5 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 2,023
