Giriş
The RAM is located under the plastic casing of the laptop. Before starting the guide, make sure the laptop's charger is not plugged in.
Neye ihtiyacın var
Start by having the laptop upside down on a hard flat surface.
Find and unscrew the 6.65 mm Phillips #1 screw.
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Everything I've read says you can only upgrade from the 1gb ram to a 2gig. Here's what I just installed: http://amzn.to/2x0flty and so far its working great...I notice a difference in speed, although this thing is still slow.
