Ana içeriğe geç
Asus Eee PC 1008ha Graphics Card Replacement
Neye ihtiyacın var
  1. Asus Eee PC 1008ha Graphics Card Replacement, Battery: adım 1, 1 resimden 1.
    • Using the plastic opening tool, carefully pry the top panel from the base.
  2. Asus Eee PC 1008ha Graphics Card Replacement: adım 2, 3 resimden 1. Asus Eee PC 1008ha Graphics Card Replacement: adım 2, 3 resimden 2. Asus Eee PC 1008ha Graphics Card Replacement: adım 2, 3 resimden 3.
    • Lift the side of the keyboard.
    • Disconnect the attached ribbon located underneath the keyboard.
    • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
  3. Asus Eee PC 1008ha Graphics Card Replacement: adım 3, 2 resimden 1. Asus Eee PC 1008ha Graphics Card Replacement: adım 3, 2 resimden 2.
    • Use your fingers to lift the battery and gently disconnect the wires from the base.
  4. Asus Eee PC 1008ha Graphics Card Replacement, Graphics Card: adım 4, 1 resimden 1.
    • Remove the two 2mm screws from the graphics card.
  5. Asus Eee PC 1008ha Graphics Card Replacement: adım 5, 3 resimden 1. Asus Eee PC 1008ha Graphics Card Replacement: adım 5, 3 resimden 2. Asus Eee PC 1008ha Graphics Card Replacement: adım 5, 3 resimden 3.
    • Flip over the graphics card.
    • Pull the black plastic locking mechanism towards the golden ribbon to unlock.
    • Pull out the ribbon.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alex Powers
101 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-52, Johann Spring 2013 Cal Poly, Team 21-52, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S21G52
4 Üyeler
11 adet Kılavuz yazıldı
Bir Yorum
Is this the graphics card?
Is this pc has no integrated graphics card?
JUAN LUIS GARCIA BRAVO - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 3,608
