Ana içeriğe geç
Asus Eee PC 1008ha Screen Replacement
Neye ihtiyacın var
  1. Asus Eee PC 1008ha Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Using the plastic opening tool, carefully pry the top panel from the base.
  2. Asus Eee PC 1008ha Screen Replacement: adım 2, 3 resimden 1. Asus Eee PC 1008ha Screen Replacement: adım 2, 3 resimden 2. Asus Eee PC 1008ha Screen Replacement: adım 2, 3 resimden 3.
    • Lift the side of the keyboard.
    • Disconnect the attached ribbon located underneath the keyboard.
    • Place your index finger in the hole on the right side of the keyboard tray and lift the tray.
  3. Asus Eee PC 1008ha Screen Replacement: adım 3, 2 resimden 1. Asus Eee PC 1008ha Screen Replacement: adım 3, 2 resimden 2.
    • Use your fingers to lift the battery and gently disconnect the wires from the base.
  4. Asus Eee PC 1008ha Screen Replacement, LCD Screen: adım 4, 2 resimden 1. Asus Eee PC 1008ha Screen Replacement, LCD Screen: adım 4, 2 resimden 2.
    • Using the Phillips #00 screwdriver, unscrew the 4mm screws from the rightmost circuit board.
    • Carefully pull the circuit board away from side of device base.
  5. Asus Eee PC 1008ha Screen Replacement: adım 5, 3 resimden 1. Asus Eee PC 1008ha Screen Replacement: adım 5, 3 resimden 2. Asus Eee PC 1008ha Screen Replacement: adım 5, 3 resimden 3.
    • Using the Phillips #00 screwdriver, unscrew the 4mm screws attaching screen to base from both sides.
    • Gently lift the screen portion from the base.
  6. Asus Eee PC 1008ha Screen Replacement: adım 6, 2 resimden 1. Asus Eee PC 1008ha Screen Replacement: adım 6, 2 resimden 2.
    • Using the Plastic Opening Tool, pry the six small chits from the face of the screen portion.
    • Using the Phillips #00 screwdriver, unscrew the two 2mm and four 4mm screws from underneath the chits.
  7. Asus Eee PC 1008ha Screen Replacement: adım 7, 2 resimden 1. Asus Eee PC 1008ha Screen Replacement: adım 7, 2 resimden 2.
    • Slide the Plastic Opening Tool under the edge of the screen bezel to release the front panel of the screen.
  8. Asus Eee PC 1008ha Screen Replacement: adım 8, 2 resimden 1. Asus Eee PC 1008ha Screen Replacement: adım 8, 2 resimden 2.
    • Using the Phillips #00 screwdriver, unscrew the 2mm screws from the perimeter of the screen.
    • Use your fingers to hold the screen and carefully lift it from the base.
  9. Asus Eee PC 1008ha Screen Replacement: adım 9, 2 resimden 1. Asus Eee PC 1008ha Screen Replacement: adım 9, 2 resimden 2.
    • Use your fingers to peel back the adhesive tape located on the back of the screen.
    • Disconnect the wire from the screen.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Michael Dooley
138 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-52, Johann Spring 2013 Cal Poly, Team 21-52, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S21G52
4 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 3,237
