Ana içeriğe geç
Asus Eee PC 1008ha Trackpad Mouse Clicker Replacement
Neye ihtiyacın var
    1. Asus Eee PC 1008ha Trackpad Mouse Clicker Replacement, Trackpad Mouse Clicker (the button's on the bottom of the trackpad): adım 1, 1 resimden 1.
      • Use an opening too to carefully separate the palm rest assembly from the base of the laptop.
      • Move the opening tool around the perimeter of the palm rest and the base and use it as a wedge.
      • You will need to undo the clips holding the two parts together with the opening tool. Be careful not to break the clips.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Eee PC 1008ha Trackpad Mouse Clicker Replacement: adım 2, 2 resimden 1. Asus Eee PC 1008ha Trackpad Mouse Clicker Replacement: adım 2, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Use a spudger to open the cable locks and remove the ribbon cables using your hands or tweezers.
      • Using a Phillips #00 screwdriver, remove the two 4 mm screws on either side of the circuit board.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Michael Dooley
138 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-52, Johann Spring 2013 Cal Poly, Team 21-52, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S21G52
4 Üyeler
30 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 39
Her zaman: 1,366
