Ana içeriğe geç
Asus Eee PC 1201HAB Hard Drive Replacement
Neye ihtiyacın var
  1. Asus Eee PC 1201HAB Hard Drive Replacement, Keyboard: adım 1, 2 resimden 1. Asus Eee PC 1201HAB Hard Drive Replacement, Keyboard: adım 1, 2 resimden 2.
    • Use a plastic opening tool and carefully pry the top panel from the base.
  2. Asus Eee PC 1201HAB Hard Drive Replacement: adım 2, 3 resimden 1. Asus Eee PC 1201HAB Hard Drive Replacement: adım 2, 3 resimden 2. Asus Eee PC 1201HAB Hard Drive Replacement: adım 2, 3 resimden 3.
    • Slowly lift the keyboard from the base.
    • Disconnect the attached ribbon from under the keyboard.
  3. Asus Eee PC 1201HAB Hard Drive Replacement: adım 3, 1 resimden 1.
    • Remove the keyboard.
  4. Asus Eee PC 1201HAB Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 1. Asus Eee PC 1201HAB Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Lay the laptop with the back facing up.
    • With a Phillips #0 screwdriver, remove the eight 6mm screws on the back of the laptop.
  5. Asus Eee PC 1201HAB Hard Drive Replacement: adım 5, 3 resimden 1. Asus Eee PC 1201HAB Hard Drive Replacement: adım 5, 3 resimden 2. Asus Eee PC 1201HAB Hard Drive Replacement: adım 5, 3 resimden 3.
    • Slide the tabs outward to remove the battery.
  6. Asus Eee PC 1201HAB Hard Drive Replacement: adım 6, 2 resimden 1. Asus Eee PC 1201HAB Hard Drive Replacement: adım 6, 2 resimden 2.
    • Flip the device so that you are facing the screen.
    • Remove the ten 4mm screws on the silver panel under the keyboard using a Phillips #0 screwdriver.
  7. Asus Eee PC 1201HAB Hard Drive Replacement: adım 7, 3 resimden 1. Asus Eee PC 1201HAB Hard Drive Replacement: adım 7, 3 resimden 2. Asus Eee PC 1201HAB Hard Drive Replacement: adım 7, 3 resimden 3.
    • Using a plastic opening tool, remove the top panel of the laptop.
  8. Asus Eee PC 1201HAB Hard Drive Replacement: adım 8, 2 resimden 1. Asus Eee PC 1201HAB Hard Drive Replacement: adım 8, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the four 4mm screws connecting the hard drive.
  9. Asus Eee PC 1201HAB Hard Drive Replacement: adım 9, 1 resimden 1.
    • Remove and replace the hard drive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Katherine Chan
353 İtibar
2 adet Kılavuz yazıldı
Ekip
UC Davis, Team S7-G3, Lore Fall 2018 UC Davis, Team S7-G3, Lore Fall 2018 üyesi
UCD-LORE-F18S7G3
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 21
Her zaman: 865
