Ana içeriğe geç
Asus Eee PC 1201N Hard Drive Replacement
Neye ihtiyacın var
  1. Asus Eee PC 1201N Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
  2. Asus Eee PC 1201N Hard Drive Replacement: adım 2, 1 resimden 1.
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
  3. Asus Eee PC 1201N Hard Drive Replacement: adım 3, 1 resimden 1.
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
  4. Asus Eee PC 1201N Hard Drive Replacement, Keyboard: adım 4, 2 resimden 1. Asus Eee PC 1201N Hard Drive Replacement, Keyboard: adım 4, 2 resimden 2.
    • Open the netbook to find the four small grooves along the top of the keyboard.
    • Pry the keyboard up using the plastic opening tool.
  5. Asus Eee PC 1201N Hard Drive Replacement: adım 5, 2 resimden 1. Asus Eee PC 1201N Hard Drive Replacement: adım 5, 2 resimden 2.
    • Tilt the keyboard away from you to access the connector. Gently push the lock toward the screen to unlock it and slide the ribbon out.
    • Remove the keyboard.
  6. Asus Eee PC 1201N Hard Drive Replacement, Hard Drive: adım 6, 1 resimden 1.
    • Turn the netbook over and remove the eight 6.5mm screws using the J0 Phillips head screwdriver.
  7. Asus Eee PC 1201N Hard Drive Replacement: adım 7, 2 resimden 1. Asus Eee PC 1201N Hard Drive Replacement: adım 7, 2 resimden 2.
    • Turn the netbook back over and remove the ten 4.5mm screws using the J0 Phillips head screwdriver.
    • Remove the cover plate by sliding the plastic opening tool around the entire edge of the plate.
  8. Asus Eee PC 1201N Hard Drive Replacement: adım 8, 1 resimden 1.
    • Flip up the retaining flap on the ZIF connector. Then, pull the blue tab for the touchpad connector before removing the cover plate completely.
  9. Asus Eee PC 1201N Hard Drive Replacement: adım 9, 1 resimden 1.
    • Remove the four 4.6mm screws with the J0 Phillips head screwdriver.
  10. Asus Eee PC 1201N Hard Drive Replacement: adım 10, 2 resimden 1. Asus Eee PC 1201N Hard Drive Replacement: adım 10, 2 resimden 2.
    • Slide the hard drive to the right and then lift it straight out of the netbook.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Trae Mikesell
394 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-3, Nance Fall 2016 USF Tampa, Team 2-3, Nance Fall 2016 üyesi
USFT-NANCE-F16S2G3
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 17
Her zaman: 3,372
