Ana içeriğe geç
Asus Eee PC 1201N Keyboard Replacement
Neye ihtiyacın var
  1. Asus Eee PC 1201N Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
    FixBot'a Sor
    Yorum Ekle
  2. Asus Eee PC 1201N Keyboard Replacement: adım 2, 1 resimden 1.
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
    FixBot'a Sor
    Yorum Ekle
  3. Asus Eee PC 1201N Keyboard Replacement: adım 3, 1 resimden 1.
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
    FixBot'a Sor
    Yorum Ekle
  4. Asus Eee PC 1201N Keyboard Replacement, Keyboard: adım 4, 2 resimden 1. Asus Eee PC 1201N Keyboard Replacement, Keyboard: adım 4, 2 resimden 2.
    • Open the netbook to find the four small grooves along the top of the keyboard.
    • Pry the keyboard up using the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  5. Asus Eee PC 1201N Keyboard Replacement: adım 5, 2 resimden 1. Asus Eee PC 1201N Keyboard Replacement: adım 5, 2 resimden 2.
    • Tilt the keyboard away from you to access the connector. Gently push the lock toward the screen to unlock it and slide the ribbon out.
    • Remove the keyboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Trae Mikesell
397 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-3, Nance Fall 2016 USF Tampa, Team 2-3, Nance Fall 2016 üyesi
USFT-NANCE-F16S2G3
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 35
Her zaman: 773
