Ana içeriğe geç
Asus Eee PC 1201N RAM Replacement
Neye ihtiyacın var
  1. Asus Eee PC 1201N RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the netbook over.
    • Be sure to unplug the netbook and power off the device while working.
  2. Asus Eee PC 1201N RAM Replacement: adım 2, 1 resimden 1.
    • Push open both tabs on either side of the battery.
    • The tab on the left will click open and stay in place until you close it.
  3. Asus Eee PC 1201N RAM Replacement: adım 3, 1 resimden 1.
    • Pull the tab on the right open, while you remove battery with your other hand.
    • Pull the battery straight out ensuring that you don't damage any connectors.
  4. Asus Eee PC 1201N RAM Replacement, RAM: adım 4, 2 resimden 1. Asus Eee PC 1201N RAM Replacement, RAM: adım 4, 2 resimden 2.
    • Remove the two 4.6mm screws using the J0 Phillips head screwdriver.
    • Then use the plastic opening tool to open the RAM door.
  5. Asus Eee PC 1201N RAM Replacement: adım 5, 1 resimden 1.
    • Push the tabs on the side of the RAM to release.
    • Only push the tabs over slightly to ensure you do not break them.
  6. Asus Eee PC 1201N RAM Replacement: adım 6, 1 resimden 1.
    • Remove the RAM by pulling it towards you.
Sonuç
Trae Mikesell
394 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-3, Nance Fall 2016 USF Tampa, Team 2-3, Nance Fall 2016 üyesi
USFT-NANCE-F16S2G3
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,023
