Ana içeriğe geç
Asus Eee PC 1215N Hard Drive Replacement
Neye ihtiyacın var
  1. Asus Eee PC 1215N Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Asus Eee PC 1215N Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the power off and turn the netbook upside down.
    • Slide both battery catches together to release the battery.
    • Slide the battery out.
  2. Asus Eee PC 1215N Hard Drive Replacement, RAM: adım 2, 3 resimden 1. Asus Eee PC 1215N Hard Drive Replacement, RAM: adım 2, 3 resimden 2. Asus Eee PC 1215N Hard Drive Replacement, RAM: adım 2, 3 resimden 3.
    • Locate the memory compartment.
    • Using a Plastic Opening Tools, remove the screw rubber cover.
    • Remove the screw.
  3. Asus Eee PC 1215N Hard Drive Replacement: adım 3, 1 resimden 1.
    • Use a Plastic Opening Tools near the screw hole to release the cover.
    • Remove the cover
  4. Asus Eee PC 1215N Hard Drive Replacement: adım 4, 2 resimden 1. Asus Eee PC 1215N Hard Drive Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Spudger
    $3.99
    • Using a Spudger, push both right and left metal clip to release one of the RAM module.
    • Slide out the RAM module.
    • Do the same with the second RAM module if necessary.
  5. Asus Eee PC 1215N Hard Drive Replacement, Top Cover (Touchpad): adım 5, 1 resimden 1.
    • Remove the screws as necessary.
    • For top cover removing, only remove the 2 bottom screws.
    • For Keyboard removing, remove all 4 screws.
    • The one short screw paterns to uper left screw hole directly on the PCB.
  6. Asus Eee PC 1215N Hard Drive Replacement: adım 6, 3 resimden 1. Asus Eee PC 1215N Hard Drive Replacement: adım 6, 3 resimden 2. Asus Eee PC 1215N Hard Drive Replacement: adım 6, 3 resimden 3.
    • Use a Plastic Opening Tools to release the top cover.
    • Start from the left side.
    • Go around on the bottom
    • Finish with the right side.
    • The top cover is still connected to the PCB with the touchpad ribbon. Handle it carefully.
  7. Asus Eee PC 1215N Hard Drive Replacement: adım 7, 2 resimden 1. Asus Eee PC 1215N Hard Drive Replacement: adım 7, 2 resimden 2.
    Spudger
    $3.99
    • Carefully slide the top cover to the bottom in order to see the touchpad connector on the PCB.
    • Use a Spudger to slide the conector attachment black part and release the ribbon from the PCB.
    • Now you can remove the top cover
  8. Asus Eee PC 1215N Hard Drive Replacement, Keyboard: adım 8, 3 resimden 1. Asus Eee PC 1215N Hard Drive Replacement, Keyboard: adım 8, 3 resimden 2. Asus Eee PC 1215N Hard Drive Replacement, Keyboard: adım 8, 3 resimden 3.
    • Make sure that the two upper screws inside the RAM compartment are removed before to continue. (Refer to Step 5).
    • Remove the keyboard 4 screws on the bottom.
    • Use a Plastic Opening Tools to release the keyboard clips on the left and right side.
  9. Asus Eee PC 1215N Hard Drive Replacement: adım 9, 1 resimden 1.
    Spudger
    $3.99
    • At this step, the keyboard is still maintained with double-sided tape between the keyboard underside and the metallic PCB protector.
    • Carefully slide a Spudger between the keyboard underside and the metallic PCB protector near the center/right at the bottom. Use the spudger as a lever to release the keyboard from the metallic PCB protector.
    • The keyboard is still connected to the PCB with a ribbon. Handle it carefully.
  10. Asus Eee PC 1215N Hard Drive Replacement: adım 10, 2 resimden 1. Asus Eee PC 1215N Hard Drive Replacement: adım 10, 2 resimden 2.
    Spudger
    $3.99
    • Carefully slide the keyboard to the top in order to see the ribbon connector on the PCB.
    • Use a Spudger to slide the connector attachment black part and release the ribbon from the PCB.
    • Now you can remove the keyboard.
  11. Asus Eee PC 1215N Hard Drive Replacement, Metallic PCB protector plate: adım 11, 3 resimden 1. Asus Eee PC 1215N Hard Drive Replacement, Metallic PCB protector plate: adım 11, 3 resimden 2. Asus Eee PC 1215N Hard Drive Replacement, Metallic PCB protector plate: adım 11, 3 resimden 3.
    • Peel off the protective tape at the bottom left corner.
    • Peel off the warranty void at the bottom right corner and remove the screw below.
    • Remove the 6 other screws.
  12. Asus Eee PC 1215N Hard Drive Replacement: adım 12, 2 resimden 1. Asus Eee PC 1215N Hard Drive Replacement: adım 12, 2 resimden 2.
    • Remove the protector plate.
  13. Asus Eee PC 1215N Hard Drive Replacement, Hard Drive: adım 13, 3 resimden 1. Asus Eee PC 1215N Hard Drive Replacement, Hard Drive: adım 13, 3 resimden 2. Asus Eee PC 1215N Hard Drive Replacement, Hard Drive: adım 13, 3 resimden 3.
    • Remove the four Phillips #00 screws from the hard drive caddy.
    • Peel off any tape covering the hard drive, there is no need to remove it entirely.
  14. Asus Eee PC 1215N Hard Drive Replacement: adım 14, 3 resimden 1. Asus Eee PC 1215N Hard Drive Replacement: adım 14, 3 resimden 2. Asus Eee PC 1215N Hard Drive Replacement: adım 14, 3 resimden 3.
    • Unplug the hard drive by sliding it to the right, toward the USB ports.
    • Remove the hard drive.
Sonuç
25 farklı kişi bu kılavuzu tamamladı.
Gaetan
9.586 İtibar
18 adet Kılavuz yazıldı
7Kılavuz Yorumları
I've just upgraded my 1215N HDD using this guide. This is very good step by step guide. A WIndows 10 Pro install managed to wreck the pre-installed HDD.
Like Tolidano , I just used a normal flat head screwdriver and a Philips screwdriver to carry out the HDD swap. I'm now in the process of installing Windows 10 Pro on to the new HDD.
Richard Bijster - Yanıt
Very good guide! I my case i need to remove 2 screws from the battery compartment to remove the keyboard
gus - Yanıt
I also had to remove the two (tiny, but phillips #00) screws from the battery compartment.
I actually went further and removed the motherboard to clean the fan. It wasn't too hard thanks to your guide!
Franciozzy - Yanıt
I, too had to remove the battery compartment screws. Other than that, and that I couldn’t get the keyboard cable out, the replacement went flawlessly.
Guy, Just Some -
Great stuff, swapped original HD for an SSD. Thank you for this!
Steven - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 36
Her zaman: 16,068
