Neye ihtiyacın var
Turn the power off and turn the netbook upside down.
Slide both battery catches together to release the battery.
Slide the battery out.
Remove screws on the battery compartment.
Locate the memory compartment.
Using a Plastic Opening Tools, remove the screw rubber cover.
Remove the screw.
Remove the screws as necessary.
For top cover removing, only remove the 2 bottom screws.
The one short screw paterns to uper left screw hole directly on the PCB.
Use a Plastic Opening Tools to release the top cover.
Start from the left side.
Go around on the bottom
Finish with the right side.
excellent guide. but be careful - it's very easy to broke narrow plastic clip :(
Remove the keyboard 4 screws on the bottom.
Use a Plastic Opening Tools to release the keyboard clips on the left and right side.
Bir başkası bu kılavuzu tamamladı.
While there is a fairly long list of tools listed here, I was able to complete the entire guide using only a 3/64" flathead mini screwdriver (the kind you get for $0.99). I replaced the stock 500GB 5400RPM drive with the updated 7200RPM slim drive of the same line with no issues. The BIOS picked it up immediately, and I need only reinstall an OS.
Tolidano - Yanıt
Missing step: remove the two screws under the battery, otherwise the keyboard won’t come off
Andrea Borgia - Yanıt
