Ana içeriğe geç
Asus Eee PC 1215N Metallic PCB protector plate Replacement
Neye ihtiyacın var
  1. Asus Eee PC 1215N Metallic PCB protector plate Replacement, Battery: adım 1, 2 resimden 1. Asus Eee PC 1215N Metallic PCB protector plate Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the power off and turn the netbook upside down.
    • Slide both battery catches together to release the battery.
    • Slide the battery out.
  2. Asus Eee PC 1215N Metallic PCB protector plate Replacement, RAM: adım 2, 3 resimden 1. Asus Eee PC 1215N Metallic PCB protector plate Replacement, RAM: adım 2, 3 resimden 2. Asus Eee PC 1215N Metallic PCB protector plate Replacement, RAM: adım 2, 3 resimden 3.
    • Locate the memory compartment.
    • Using a Plastic Opening Tools, remove the screw rubber cover.
    • Remove the screw.
  3. Asus Eee PC 1215N Metallic PCB protector plate Replacement: adım 3, 1 resimden 1.
    • Use a Plastic Opening Tools near the screw hole to release the cover.
    • Remove the cover
  4. Asus Eee PC 1215N Metallic PCB protector plate Replacement: adım 4, 2 resimden 1. Asus Eee PC 1215N Metallic PCB protector plate Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Spudger
    $3.99
    Satın Al
    • Using a Spudger, push both right and left metal clip to release one of the RAM module.
    • Slide out the RAM module.
    • Do the same with the second RAM module if necessary.
  5. Asus Eee PC 1215N Metallic PCB protector plate Replacement, Top Cover (Touchpad): adım 5, 1 resimden 1.
    • Remove the screws as necessary.
    • For top cover removing, only remove the 2 bottom screws.
    • For Keyboard removing, remove all 4 screws.
    • The one short screw paterns to uper left screw hole directly on the PCB.
  6. Asus Eee PC 1215N Metallic PCB protector plate Replacement: adım 6, 3 resimden 1. Asus Eee PC 1215N Metallic PCB protector plate Replacement: adım 6, 3 resimden 2. Asus Eee PC 1215N Metallic PCB protector plate Replacement: adım 6, 3 resimden 3.
    • Use a Plastic Opening Tools to release the top cover.
    • Start from the left side.
    • Go around on the bottom
    • Finish with the right side.
    • The top cover is still connected to the PCB with the touchpad ribbon. Handle it carefully.
  7. Asus Eee PC 1215N Metallic PCB protector plate Replacement: adım 7, 2 resimden 1. Asus Eee PC 1215N Metallic PCB protector plate Replacement: adım 7, 2 resimden 2.
    Spudger
    $3.99
    Satın Al
    • Carefully slide the top cover to the bottom in order to see the touchpad connector on the PCB.
    • Use a Spudger to slide the conector attachment black part and release the ribbon from the PCB.
    • Now you can remove the top cover
  8. Asus Eee PC 1215N Metallic PCB protector plate Replacement, Keyboard: adım 8, 3 resimden 1. Asus Eee PC 1215N Metallic PCB protector plate Replacement, Keyboard: adım 8, 3 resimden 2. Asus Eee PC 1215N Metallic PCB protector plate Replacement, Keyboard: adım 8, 3 resimden 3.
    • Make sure that the two upper screws inside the RAM compartment are removed before to continue. (Refer to Step 5).
    • Remove the keyboard 4 screws on the bottom.
    • Use a Plastic Opening Tools to release the keyboard clips on the left and right side.
  9. Asus Eee PC 1215N Metallic PCB protector plate Replacement: adım 9, 1 resimden 1.
    Spudger
    $3.99
    Satın Al
    • At this step, the keyboard is still maintained with double-sided tape between the keyboard underside and the metallic PCB protector.
    • Carefully slide a Spudger between the keyboard underside and the metallic PCB protector near the center/right at the bottom. Use the spudger as a lever to release the keyboard from the metallic PCB protector.
    • The keyboard is still connected to the PCB with a ribbon. Handle it carefully.
  10. Asus Eee PC 1215N Metallic PCB protector plate Replacement: adım 10, 2 resimden 1. Asus Eee PC 1215N Metallic PCB protector plate Replacement: adım 10, 2 resimden 2.
    Spudger
    $3.99
    Satın Al
    • Carefully slide the keyboard to the top in order to see the ribbon connector on the PCB.
    • Use a Spudger to slide the connector attachment black part and release the ribbon from the PCB.
    • Now you can remove the keyboard.
  11. Asus Eee PC 1215N Metallic PCB protector plate Replacement, Metallic PCB protector plate: adım 11, 3 resimden 1. Asus Eee PC 1215N Metallic PCB protector plate Replacement, Metallic PCB protector plate: adım 11, 3 resimden 2. Asus Eee PC 1215N Metallic PCB protector plate Replacement, Metallic PCB protector plate: adım 11, 3 resimden 3.
    • Peel off the protective tape at the bottom left corner.
    • Peel off the warranty void at the bottom right corner and remove the screw below.
    • Remove the 6 other screws.
  12. Asus Eee PC 1215N Metallic PCB protector plate Replacement: adım 12, 2 resimden 1. Asus Eee PC 1215N Metallic PCB protector plate Replacement: adım 12, 2 resimden 2.
    • Remove the protector plate.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Gaetan
9.574 İtibar
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 3,476
