Ana içeriğe geç
Asus Eee PC 900 Keyboard Replacement
Neye ihtiyacın var
    1. Asus Eee PC 900 Keyboard Replacement, Battery: adım 1, 3 resimden 1. Asus Eee PC 900 Keyboard Replacement, Battery: adım 1, 3 resimden 2. Asus Eee PC 900 Keyboard Replacement, Battery: adım 1, 3 resimden 3.
      • Slide the battery's locking tabs from the locked position to unlocked positions.
      • The right tab is unlocked when a red dot is showing.
      • The left tab will have to be held in the unlocked position in order to release the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Eee PC 900 Keyboard Replacement: adım 2, 1 resimden 1.
      • Slide the battery out while holding the left locking tab in the unlocked position.
      FixBot'a Sor
      Yorum Ekle
    1. Asus Eee PC 900 Keyboard Replacement, Keyboard: adım 3, 2 resimden 1. Asus Eee PC 900 Keyboard Replacement, Keyboard: adım 3, 2 resimden 2.
      • Caution Follow this step to detach the upper portion of the keyboard, but do not remove it from the laptop. Damage to the keyboard's ribbon cable may result if improperly executed.
      • Identify the three metal tabs holding down the laptop's keyboard.
      • Using a spudger, depress each metal tab to remove the keyboard.
      • The upper part of the keyboard should "pop up" from its holder.
      FixBot'a Sor
      Yorum Ekle
    2. Asus Eee PC 900 Keyboard Replacement: adım 4, 2 resimden 1. Asus Eee PC 900 Keyboard Replacement: adım 4, 2 resimden 2.
      • Clips hold the bottom portion of the keyboard to the laptop. Gently lift the upper portion of the keyboard and then move the entire keyboard towards the computer's screen until the ribbon cable is visible.
      FixBot'a Sor
      Yorum Ekle
    3. Asus Eee PC 900 Keyboard Replacement: adım 5, 1 resimden 1.
      • Using a spudger, gently push the two black pins holding the ribbon cable towards the computer's screen.
      • Slide the keyboard's ribbon cable from the connector.
      FixBot'a Sor
      Yorum Ekle
    4. Asus Eee PC 900 Keyboard Replacement: adım 6, 1 resimden 1.
      • Remove the keyboard by lifting upwards.
      FixBot'a Sor
      Yorum Ekle
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Sheldon Chu
1.176 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-27, Amido Winter 2012 Cal Poly, Team 3-27, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S3G27
4 Üyeler
24 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 38
Her zaman: 10,675
