Ana içeriğe geç
Asus Eee PC 900 RAM Replacement
Neye ihtiyacın var
  1. Asus Eee PC 900 RAM Replacement, Battery: adım 1, 3 resimden 1. Asus Eee PC 900 RAM Replacement, Battery: adım 1, 3 resimden 2. Asus Eee PC 900 RAM Replacement, Battery: adım 1, 3 resimden 3.
    • Slide the battery's locking tabs from the locked position to unlocked positions.
    • The right tab is unlocked when a red dot is showing.
    • The left tab will have to be held in the unlocked position in order to release the battery.
  2. Asus Eee PC 900 RAM Replacement: adım 2, 1 resimden 1.
    • Slide the battery out while holding the left locking tab in the unlocked position.
  3. Asus Eee PC 900 RAM Replacement, RAM: adım 3, 2 resimden 1. Asus Eee PC 900 RAM Replacement, RAM: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Remove the sticker from the RAM compartment using a pair of tweezers.
  4. Asus Eee PC 900 RAM Replacement: adım 4, 2 resimden 1. Asus Eee PC 900 RAM Replacement: adım 4, 2 resimden 2.
    • Remove the two 4.8 mm screws using a Phillips #0 screwdriver.
  5. Asus Eee PC 900 RAM Replacement: adım 5, 1 resimden 1.
    • Open up the cover from the bottom by carefully prying it open with a plastic opening tool.
    • Be gentle when prying open the cover in order to not damage it.
  6. Asus Eee PC 900 RAM Replacement: adım 6, 1 resimden 1.
    • Remove the back cover by pulling up on the side that had the screws.
  7. Asus Eee PC 900 RAM Replacement: adım 7, 2 resimden 1. Asus Eee PC 900 RAM Replacement: adım 7, 2 resimden 2.
    • Use a spudger to push the top of the pin on the right towards the right (so it isn't holding the RAM chip).
    • Do the same for the left pin. Push the top of the pin towards the left.
    • The RAM should pop up.
  8. Asus Eee PC 900 RAM Replacement: adım 8, 1 resimden 1.
    • Remove the RAM chip by grabbing the top of the chip and pulling it upwards.
    • Be gentle when removing the RAM because it is a very delicate part and you do not want to break any of the pins in the computer.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Brian Carreon
300 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-27, Amido Winter 2012 Cal Poly, Team 3-27, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S3G27
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 75
Her zaman: 9,433
