Ana içeriğe geç
Asus Eee PC 900 SSD Replacement
Neye ihtiyacın var
  1. Asus Eee PC 900 SSD Replacement, Battery: adım 1, 3 resimden 1. Asus Eee PC 900 SSD Replacement, Battery: adım 1, 3 resimden 2. Asus Eee PC 900 SSD Replacement, Battery: adım 1, 3 resimden 3.
    • Slide the battery's locking tabs from the locked position to unlocked positions.
    • The right tab is unlocked when a red dot is showing.
    • The left tab will have to be held in the unlocked position in order to release the battery.
  2. Asus Eee PC 900 SSD Replacement: adım 2, 1 resimden 1.
    • Slide the battery out while holding the left locking tab in the unlocked position.
  3. Asus Eee PC 900 SSD Replacement, SSD: adım 3, 3 resimden 1. Asus Eee PC 900 SSD Replacement, SSD: adım 3, 3 resimden 2. Asus Eee PC 900 SSD Replacement, SSD: adım 3, 3 resimden 3.
    • Remove the small sticker on the right side of the SSD/RAM compartment cover.
    • Remove the two 4.76 mm Phillips #0 screws securing the SSD/RAM compartment cover.
  4. Asus Eee PC 900 SSD Replacement: adım 4, 2 resimden 1. Asus Eee PC 900 SSD Replacement: adım 4, 2 resimden 2.
    • Using a plastic opening tool, lift up the bottom of the SSD/RAM compartment cover.
    • Lift the cover away from the laptop.
  5. Asus Eee PC 900 SSD Replacement: adım 5, 3 resimden 1. Asus Eee PC 900 SSD Replacement: adım 5, 3 resimden 2. Asus Eee PC 900 SSD Replacement: adım 5, 3 resimden 3.
    • Remove the two 4.76 mm Phillips #0 screws that secure the SSD.
    • When the screws are removed, one end of the SSD should pop up.
    • Slide the SSD out of its socket and lift it out of the compartment.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Brian Carreon
300 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-27, Amido Winter 2012 Cal Poly, Team 3-27, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S3G27
4 Üyeler
16 adet Kılavuz yazıldı
5Kılavuz Yorumları
What for specifications do the SSD has? I want to replace, too but do not know the execactly specs. I bought a 30GB m-sata ssd and this is not accepted by bios and does not work.
Marcus - Yanıt
Refering from this site: http://www.minipciessd.com/
It seems you'll need a miniPCIe SSD and not a m-sata (even if the form factor seems the same) and that's why your bios doesn't recognize it.
adrien - Yanıt
There are now miniPCIe mSATA adapters. I plan to try this.
ejolson - Yanıt
Same problem here. I ended up putting my “new!” 64GB SSD in an adaptor and used it for a few years until it wore out!
Evidently the chips aren’t much good as withstood less than 700GB of writes according to the onboard diagnostics.
Strangely enough the adaptor worked with the original 16GB SSD and the 64.
Andre De Guerin - Yanıt
what kind of adapter you use? My ssd died….
rui fontes -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 21
Son 30 gün: 145
Her zaman: 45,752
