Ana içeriğe geç
Asus Eee PC 900 Top Cover Replacement
Neye ihtiyacın var
  1. Asus Eee PC 900 Top Cover Replacement, Battery: adım 1, 3 resimden 1. Asus Eee PC 900 Top Cover Replacement, Battery: adım 1, 3 resimden 2. Asus Eee PC 900 Top Cover Replacement, Battery: adım 1, 3 resimden 3.
    • Slide the battery's locking tabs from the locked position to unlocked positions.
    • The right tab is unlocked when a red dot is showing.
    • The left tab will have to be held in the unlocked position in order to release the battery.
  2. Asus Eee PC 900 Top Cover Replacement: adım 2, 1 resimden 1.
    • Slide the battery out while holding the left locking tab in the unlocked position.
  3. Asus Eee PC 900 Top Cover Replacement, Keyboard: adım 3, 2 resimden 1. Asus Eee PC 900 Top Cover Replacement, Keyboard: adım 3, 2 resimden 2.
    • Caution Follow this step to detach the upper portion of the keyboard, but do not remove it from the laptop. Damage to the keyboard's ribbon cable may result if improperly executed.
    • Identify the three metal tabs holding down the laptop's keyboard.
    • Using a spudger, depress each metal tab to remove the keyboard.
    • The upper part of the keyboard should "pop up" from its holder.
  4. Asus Eee PC 900 Top Cover Replacement: adım 4, 2 resimden 1. Asus Eee PC 900 Top Cover Replacement: adım 4, 2 resimden 2.
    • Clips hold the bottom portion of the keyboard to the laptop. Gently lift the upper portion of the keyboard and then move the entire keyboard towards the computer's screen until the ribbon cable is visible.
  5. Asus Eee PC 900 Top Cover Replacement: adım 5, 1 resimden 1.
    • Using a spudger, gently push the two black pins holding the ribbon cable towards the computer's screen.
    • Slide the keyboard's ribbon cable from the connector.
  6. Asus Eee PC 900 Top Cover Replacement: adım 6, 1 resimden 1.
    • Remove the keyboard by lifting upwards.
  7. Asus Eee PC 900 Top Cover Replacement, Top Cover: adım 7, 2 resimden 1. Asus Eee PC 900 Top Cover Replacement, Top Cover: adım 7, 2 resimden 2.
    • Remove the nine 4.76mm Phillips #0 screws on the top cover of the laptop.
  8. Asus Eee PC 900 Top Cover Replacement: adım 8, 2 resimden 1. Asus Eee PC 900 Top Cover Replacement: adım 8, 2 resimden 2.
    • Remove the six 4.76 mm Phillips #0 screws on the back of the laptop.
  9. Asus Eee PC 900 Top Cover Replacement: adım 9, 3 resimden 1. Asus Eee PC 900 Top Cover Replacement: adım 9, 3 resimden 2. Asus Eee PC 900 Top Cover Replacement: adım 9, 3 resimden 3.
    • Flip the laptop back over and identify the touchpad ribbon.
    • Unlock the tan locking pin from the black connector by pushing the pin to the right with a spudger.
  10. Asus Eee PC 900 Top Cover Replacement: adım 10, 1 resimden 1.
    • Slide out the touchpad's ribbon connector by pulling the blue tab to the right.
  11. Asus Eee PC 900 Top Cover Replacement: adım 11, 1 resimden 1.
    • Use a plastic opening tool to gently detach the top cover from the laptop's base. See the next step for removing the cover.
  12. Asus Eee PC 900 Top Cover Replacement: adım 12, 3 resimden 1. Asus Eee PC 900 Top Cover Replacement: adım 12, 3 resimden 2. Asus Eee PC 900 Top Cover Replacement: adım 12, 3 resimden 3.
    • Caution: To clear the audio and microphone, lift the right half and move the cover to the left (as shown in the second picture) to prevent cover damage.
    • Remove the laptop cover.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Sheldon Chu
1.140 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-27, Amido Winter 2012 Cal Poly, Team 3-27, Amido Winter 2012 üyesi
CPSU-AMIDO-W12S3G27
4 Üyeler
16 adet Kılavuz yazıldı
2Kılavuz Yorumları
If you have a 900HD, there are only 8 screws in step 7. The ninth "screw" -- the second from the right in the bottom row, to the right of the blue ribbon -- is under the hard drive. You have to remove the hard drive cover on the bottom, remove the hard drive, then remove the screw there.
burneson - Yanıt
how much the replacement of top and back cover of this laptop?
reyesdexter - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 47
Her zaman: 7,462
