Ana içeriğe geç
Asus Eee PC T101MT Fan Replacement
Neye ihtiyacın var
  1. Asus Eee PC T101MT Fan Replacement, Battery: adım 1, 1 resimden 1.
    • Before you begin, make sure your device is powered off and not connected to the power supply.
    • Turn the tablet over and position it so it matches the picture.
  2. Asus Eee PC T101MT Fan Replacement: adım 2, 1 resimden 1.
    • Locate the sliding tab on the right and slide it to the left in order to unlock the battery.
  3. Asus Eee PC T101MT Fan Replacement: adım 3, 1 resimden 1.
    • Use a plastic opening tool to lift the battery up as you slide the tab on the left to the right.
  4. Asus Eee PC T101MT Fan Replacement: adım 4, 1 resimden 1.
    • Lift the battery out of the device.
  5. Asus Eee PC T101MT Fan Replacement, Keyboard: adım 5, 3 resimden 1. Asus Eee PC T101MT Fan Replacement, Keyboard: adım 5, 3 resimden 2. Asus Eee PC T101MT Fan Replacement, Keyboard: adım 5, 3 resimden 3.
    • Turn the tablet over and open it up. Insert a nylon spudger into the slots above F1, F6, F10 to pry up the keyboard.
  6. Asus Eee PC T101MT Fan Replacement: adım 6, 1 resimden 1.
    • Once you have the keyboard out, use the nylon spudger to remove the connection. You can now replace the keyboard.
  7. Asus Eee PC T101MT Fan Replacement, Fan: adım 7, 2 resimden 1. Asus Eee PC T101MT Fan Replacement, Fan: adım 7, 2 resimden 2.
    • Peel the black strip off of the back of your Asus Eee PC T101MT to expose more screws. Remove screws from the outside of the device case (ten 7mm screws and two 8mm screws).
  8. Asus Eee PC T101MT Fan Replacement: adım 8, 1 resimden 1.
    • Remove the four 3mm screws from underneath the battery.
  9. Asus Eee PC T101MT Fan Replacement: adım 9, 1 resimden 1.
    • Remove the screws from under the keyboard. (Two 7mm and five 5mm)
  10. Asus Eee PC T101MT Fan Replacement: adım 10, 1 resimden 1.
    • Use a plastic opening tool to pry the case open and remove it.
  11. Asus Eee PC T101MT Fan Replacement: adım 11, 1 resimden 1.
    • Locate the fan and remove the screws (3mm).
  12. Asus Eee PC T101MT Fan Replacement: adım 12, 1 resimden 1.
    • Use a spudger to remove the power supply.
  13. Asus Eee PC T101MT Fan Replacement: adım 13, 1 resimden 1.
    • Remove and replace the fan.
Sonuç
Jarnell Miranda
657 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-1, Kuhn Fall 2015 Gateway, Team 1-1, Kuhn Fall 2015 üyesi
GCC-KUHN-F15S1G1
1 Üye
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 811
