Ana içeriğe geç
Asus EeeBook X205TA USB Port Replacement
Neye ihtiyacın var
    1. Asus EeeBook X205TA  USB Port Replacement, USB Port: adım 1, 2 resimden 1. Asus EeeBook X205TA  USB Port Replacement, USB Port: adım 1, 2 resimden 2.
      • Unscrew all 10 screws located on the bottom of the laptop using a Phillips #2 Screwdriver.
      • Keep in mind that some of the screws vary in length, so keep track of which screws were placed in each hole.
      FixBot'a Sor
      Yorum Ekle
    2. Asus EeeBook X205TA  USB Port Replacement: adım 2, 1 resimden 1.
      • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
      • Carefully pry open the case from several points.
      • Slowly remove the back of the laptop, revealing the parts inside.
      FixBot'a Sor
      Yorum Ekle
    3. Asus EeeBook X205TA  USB Port Replacement: adım 3, 2 resimden 1. Asus EeeBook X205TA  USB Port Replacement: adım 3, 2 resimden 2.
      • The USB ports are located on the strip that looks like the motherboard on the left side of the laptop next to the battery.
      • Unscrew the four screws using Philips #2 screwdriver located around the edge of the USB ports.
      • Unplug the battery ZIF connector from the USB ports.
      FixBot'a Sor
      Yorum Ekle
    4. Asus EeeBook X205TA  USB Port Replacement: adım 4, 1 resimden 1.
      • Carefully remove the USB ports from the laptop.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Lorena Santiago
760 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Sullivan Fall 2016 USF Tampa, Team 2-2, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S2G2
3 Üyeler
60 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 43
Her zaman: 2,997
