Ana içeriğe geç
Asus EeeBook X205TA Battery Replacement
Neye ihtiyacın var
  1. Asus EeeBook X205TA Battery Replacement, Battery: adım 1, 2 resimden 1. Asus EeeBook X205TA Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA Battery Replacement: adım 2, 1 resimden 1.
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Battery Replacement: adım 3, 2 resimden 1. Asus EeeBook X205TA Battery Replacement: adım 3, 2 resimden 2.
    • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
    • Any tape or cords that run along the battery should be carefully pushed to the side.
  4. Asus EeeBook X205TA Battery Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
  5. Asus EeeBook X205TA Battery Replacement: adım 5, 1 resimden 1.
    • Carefully lift the battery out of the laptop.
Sonuç
Follow the guide in reverse order to reassemble the device.
8 farklı kişi bu kılavuzu tamamladı.
Lorena Santiago
712 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Sullivan Fall 2016 USF Tampa, Team 2-2, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S2G2
3 Üyeler
10 adet Kılavuz yazıldı
11Kılavuz Yorumları
By any chance , Can we run this laptop without battery ? I mean directly from AC ? Please suggest
Sourabh Verma - Yanıt
No, you must have the battery on.
Tayler Grant -
is this under warenty
bla bla - Yanıt
If you have one….
Tayler Grant -
My battery is stuck on orange led mode. My laptop cannot identify the battery….
Tayler Grant - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 21
Son 30 gün: 71
Her zaman: 14,552
