Ana içeriğe geç
Asus EeeBook X205TA LED Screen Panel Chip Replacement
Neye ihtiyacın var
  1. Asus EeeBook X205TA LED Screen Panel Chip Replacement, Battery: adım 1, 2 resimden 1. Asus EeeBook X205TA LED Screen Panel Chip Replacement, Battery: adım 1, 2 resimden 2.
    • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA LED Screen Panel Chip Replacement: adım 2, 1 resimden 1.
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA LED Screen Panel Chip Replacement: adım 3, 2 resimden 1. Asus EeeBook X205TA LED Screen Panel Chip Replacement: adım 3, 2 resimden 2.
    • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
    • Any tape or cords that run along the battery should be carefully pushed to the side.
  4. Asus EeeBook X205TA LED Screen Panel Chip Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
  5. Asus EeeBook X205TA LED Screen Panel Chip Replacement: adım 5, 1 resimden 1.
    • Carefully lift the battery out of the laptop.
  6. Asus EeeBook X205TA LED Screen Panel Chip Replacement, LED Screen Panel Chip: adım 6, 1 resimden 1.
    • Locate and lift the tabs from the LED/motherboard ribbon cable.
    • Remove the cable.
  7. Asus EeeBook X205TA LED Screen Panel Chip Replacement: adım 7, 1 resimden 1.
    • Unscrew the 1 JIS 2mm screw with the J0 bit.
  8. Asus EeeBook X205TA LED Screen Panel Chip Replacement: adım 8, 1 resimden 1.
    • Remove the chip.
Sonuç
Rachael
125 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S3-G4, Baechle Spring 2017 IUPUI, Team S3-G4, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S3G4
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 25
Her zaman: 1,239
