Ana içeriğe geç
Asus EeeBook X205TA Screen Assembly Replacement
Neye ihtiyacın var
  1. Asus EeeBook X205TA Screen Assembly Replacement, Screen Assembly: adım 1, 2 resimden 1. Asus EeeBook X205TA Screen Assembly Replacement, Screen Assembly: adım 1, 2 resimden 2.
    • Unscrew all 10 screws located on the bottom of the laptop using 2mm Phillips Screwdriver.
    • Keep in mind that some of the screws vary in length, so keep track of which screws were placed in each hole.
  2. Asus EeeBook X205TA Screen Assembly Replacement: adım 2, 1 resimden 1.
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Screen Assembly Replacement: adım 3, 3 resimden 1. Asus EeeBook X205TA Screen Assembly Replacement: adım 3, 3 resimden 2. Asus EeeBook X205TA Screen Assembly Replacement: adım 3, 3 resimden 3.
    • Unscrew the four screws using Philips #2 screwdriver that connect the screen to the inside of the case for the laptop.
  4. Asus EeeBook X205TA Screen Assembly Replacement: adım 4, 1 resimden 1.
    • Unplug the No-Fuss Ribbon connector of the screen from the motherboard.
    • Carefully lift the screen away from the case.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Lorena Santiago
712 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Sullivan Fall 2016 USF Tampa, Team 2-2, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S2G2
3 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
What's that small black screen hanging out from the laptop
Tayler Grant - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 2,455
