Ana içeriğe geç
Asus EeeBook X205TA Speakers Replacement
Neye ihtiyacın var
  1. Asus EeeBook X205TA Speakers Replacement, Battery: adım 1, 2 resimden 1. Asus EeeBook X205TA Speakers Replacement, Battery: adım 1, 2 resimden 2.
    • Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
  2. Asus EeeBook X205TA Speakers Replacement: adım 2, 1 resimden 1.
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case.
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA Speakers Replacement: adım 3, 2 resimden 1. Asus EeeBook X205TA Speakers Replacement: adım 3, 2 resimden 2.
    • Unscrew all six 2mm screws using Philips #2 screws along the edges of the L-Shaped battery.
    • Any tape or cords that run along the battery should be carefully pushed to the side.
  4. Asus EeeBook X205TA Speakers Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery from the motherboard by pulling the No-Fuss Ribbon cables out of the connector.
  5. Asus EeeBook X205TA Speakers Replacement: adım 5, 1 resimden 1.
    • Carefully lift the battery out of the laptop.
  6. Asus EeeBook X205TA Speakers Replacement, Speakers: adım 6, 1 resimden 1.
    • Locate and lift the tabs from the LED/motherboard ribbon cable.
    • Remove the cable.
  7. Asus EeeBook X205TA Speakers Replacement: adım 7, 1 resimden 1.
    • Unplug the speaker cable from the motherboard.
  8. Asus EeeBook X205TA Speakers Replacement: adım 8, 1 resimden 1.
    • Pry the right speaker gently with the plastic opening tool.
  9. Asus EeeBook X205TA Speakers Replacement: adım 9, 1 resimden 1.
    • Pry the left speaker gently with the plastic opening tool.
Sonuç
Bir başkası bu kılavuzu tamamladı.
William Riggins
312 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G4, Baechle Spring 2017 IUPUI, Team S3-G4, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S3G4
4 Üyeler
6 adet Kılavuz yazıldı
2 Yorum
Thank you very much for this detailed and helpful tutorial.
andrew - Yanıt
Thanks. You’ve helped make it clearer for me!
geometry dash
Martin Tolley - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 912
