Giriş
In this guide you will learn how to replace the speakers in an Asus EeeBook X205TA.
Neye ihtiyacın var
Unscrew all ten 2mm screws located on the bottom of the laptop using a Phillips #2 screwdriver.
Locate and lift the tabs from the LED/motherboard ribbon cable.
Remove the cable.
Bir başkası bu kılavuzu tamamladı.
2 Yorum
Thanks. You’ve helped make it clearer for me!
