Ana içeriğe geç
Asus EeeBook X205TA TrackPad Replacement
Neye ihtiyacın var
  1. Asus EeeBook X205TA TrackPad Replacement, TrackPad: adım 1, 2 resimden 1. Asus EeeBook X205TA TrackPad Replacement, TrackPad: adım 1, 2 resimden 2.
    • Remove ten Phillips #00 screws located on the bottom of the laptop:
    • Seven short screws.
    • Three long screws.
  2. Asus EeeBook X205TA TrackPad Replacement: adım 2, 1 resimden 1.
    • Insert the plastic opening tool in the crevice between the back of the laptop and the rest of the case (where the hinge is).
    • Carefully pry open the case from several points.
    • Slowly remove the back of the laptop, revealing the parts inside.
  3. Asus EeeBook X205TA TrackPad Replacement: adım 3, 2 resimden 1. Asus EeeBook X205TA TrackPad Replacement: adım 3, 2 resimden 2.
    • Using the 2mm Phillips Screwdriver, carefully unscrew the four screws holding the track pad.
    • Using the Phillips #00 Screwdriver, unscrew the three screws holding the track pad.
  4. Asus EeeBook X205TA TrackPad Replacement: adım 4, 1 resimden 1.
    • Unplug the ZIF connector
  5. Asus EeeBook X205TA TrackPad Replacement: adım 5, 1 resimden 1.
    • Carefully pull the track pad from the side
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Lorena Santiago
712 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-2, Sullivan Fall 2016 USF Tampa, Team 2-2, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S2G2
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 16
Her zaman: 1,815
