Ana içeriğe geç
Asus F554LA-WS52 Disc Drive
Neye ihtiyacın var
  1. Asus F554LA-WS52 Disc Drive, Disc Drive: adım 1, 2 resimden 1. Asus F554LA-WS52 Disc Drive, Disc Drive: adım 1, 2 resimden 2.
    • Make sure the notebook is off and has been unplugged from any power source.
    • Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
    • Six (6) will be 9.6mm and four (4) will be 12.7mm.
  2. Asus F554LA-WS52 Disc Drive: adım 2, 3 resimden 1. Asus F554LA-WS52 Disc Drive: adım 2, 3 resimden 2. Asus F554LA-WS52 Disc Drive: adım 2, 3 resimden 3.
    • With a plastic opening tool, gently lift and remove the back cover to expose the internal components.
    • (Not pictured) Remove the three cables attached to the keyboard and one touch-pad.
  3. Asus F554LA-WS52 Disc Drive: adım 3, 2 resimden 1. Asus F554LA-WS52 Disc Drive: adım 3, 2 resimden 2.
    • Unscrew the three 5.7 mm hard drive-motherboard connection screws with a #0 Phillips head screwdriver.
    • Remove the small rectangular hard drive-motherboard connection board.
    • (Not pictured) Remove the hard drive.
  4. Asus F554LA-WS52 Disc Drive: adım 4, 2 resimden 1. Asus F554LA-WS52 Disc Drive: adım 4, 2 resimden 2.
    • Unscrew the four 5.7 mm battery screws with a #0 Phillips head screwdriver.
    • Remove the battery.
  5. Asus F554LA-WS52 Disc Drive: adım 5, 3 resimden 1. Asus F554LA-WS52 Disc Drive: adım 5, 3 resimden 2. Asus F554LA-WS52 Disc Drive: adım 5, 3 resimden 3.
    • Unscrew the two 2.7 mm and one 5.7 mm CD drive screws with the Phillips #00 screwdriver.
    • With the plastic opening tool, gently pry the drive out from the metal brackets that hold it in place.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Aaron Ratliff
542 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G2, Leahy Fall 2018 USF Tampa, Team S1-G2, Leahy Fall 2018 üyesi
USFT-LEAHY-F18S1G2
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 63
Her zaman: 915
