Ana içeriğe geç
Asus F554LA-WS52 Screen Replacement
Neye ihtiyacın var
  1. Asus F554LA-WS52 Screen Replacement, Screen: adım 1, 2 resimden 1. Asus F554LA-WS52 Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Remove the two plastic screw coverings from the bottom of the screen panel.
  2. Asus F554LA-WS52 Screen Replacement: adım 2, 2 resimden 1. Asus F554LA-WS52 Screen Replacement: adım 2, 2 resimden 2.
    • Remove the two 4.6mm screws using the Phillips #0 screwdriver.
  3. Asus F554LA-WS52 Screen Replacement: adım 3, 2 resimden 1. Asus F554LA-WS52 Screen Replacement: adım 3, 2 resimden 2.
    • Using the plastic opening tool, gently pry the notebook's plastic screen covering away from the screen.
  4. Asus F554LA-WS52 Screen Replacement: adım 4, 2 resimden 1. Asus F554LA-WS52 Screen Replacement: adım 4, 2 resimden 2.
    • Remove the two 4.6mm screws holding screen in place.
  5. Asus F554LA-WS52 Screen Replacement: adım 5, 3 resimden 1. Asus F554LA-WS52 Screen Replacement: adım 5, 3 resimden 2. Asus F554LA-WS52 Screen Replacement: adım 5, 3 resimden 3.
    • Carefully, lay screen down on the keyboard.
    • Be cautious as the screen will still be attached.
  6. Asus F554LA-WS52 Screen Replacement: adım 6, 3 resimden 1. Asus F554LA-WS52 Screen Replacement: adım 6, 3 resimden 2. Asus F554LA-WS52 Screen Replacement: adım 6, 3 resimden 3.
    • Remove tape that covers the visual pin connectors.
    • Gently disconnect the screen from the pin connectors and replace.
Sonuç
Aaron Ratliff
542 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G2, Leahy Fall 2018 USF Tampa, Team S1-G2, Leahy Fall 2018 üyesi
USFT-LEAHY-F18S1G2
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 35
Her zaman: 539
