Ana içeriğe geç
Asus F554LA-WS52 Touchpad Replacement
Neye ihtiyacın var
  1. Asus F554LA-WS52 Touchpad Replacement, Touchpad: adım 1, 3 resimden 1. Asus F554LA-WS52 Touchpad Replacement, Touchpad: adım 1, 3 resimden 2. Asus F554LA-WS52 Touchpad Replacement, Touchpad: adım 1, 3 resimden 3.
    • Make sure your notebook device is unplugged and turned off before opening it up.
    • Flip the notebook over and remove the 10 screws from the back plate with a #0 Phillips head screwdriver.
    • Six (6) will be 9.6mm and four (4) will be 12.7mm.
  2. Asus F554LA-WS52 Touchpad Replacement: adım 2, 3 resimden 1. Asus F554LA-WS52 Touchpad Replacement: adım 2, 3 resimden 2. Asus F554LA-WS52 Touchpad Replacement: adım 2, 3 resimden 3.
    • Once the screws are removed, carefully lift both sides of the plastic keyboard/touch pad cover with a plastic opening tool.
  3. Asus F554LA-WS52 Touchpad Replacement: adım 3, 1 resimden 1.
    • Lift the plastic cover and unplug the three data cords (not all pictured) under the cover from the keyboard and motherboard.
  4. Asus F554LA-WS52 Touchpad Replacement: adım 4, 3 resimden 1. Asus F554LA-WS52 Touchpad Replacement: adım 4, 3 resimden 2. Asus F554LA-WS52 Touchpad Replacement: adım 4, 3 resimden 3.
    • Once you've removed the plastic cover, flip it over.
    • Next, carefully remove the tape from the bottom side of your touch pad.
  5. Asus F554LA-WS52 Touchpad Replacement: adım 5, 1 resimden 1.
    • Locate and unscrew the three 3.2 mm at the top edge of the touch pad using the Phillips #0 screwdriver.
  6. Asus F554LA-WS52 Touchpad Replacement: adım 6, 3 resimden 1. Asus F554LA-WS52 Touchpad Replacement: adım 6, 3 resimden 2. Asus F554LA-WS52 Touchpad Replacement: adım 6, 3 resimden 3.
    • Gently push the front of the touch pad with your finger to remove it from its position within the keyboard.
    • Replace touch pad.
Sonuç
Clint Eagle
300 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G2, Leahy Fall 2018 USF Tampa, Team S1-G2, Leahy Fall 2018 üyesi
USFT-LEAHY-F18S1G2
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 241
