Ana içeriğe geç
Asus F6A-X2 RAM Replacement
Neye ihtiyacın var
    1. Asus F6A-X2 RAM Replacement, Battery: adım 1, 1 resimden 1.
      • Remove any power cords and turn the laptop off. Attempting to replace part of the laptop while power is running through it may cause electrocution or damage to the device.
      • Flip laptop face down and rotate so the battery is facing toward you.
      • The battery is not shown in this picture.
      • To remove the battery, place one finger on each of the two black slide tabs. Push each tab toward the center of the laptop to release the lock.
      • Slide the battery toward you and lift it out of the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. Asus F6A-X2 RAM Replacement, Back Access Panel: adım 2, 2 resimden 1. Asus F6A-X2 RAM Replacement, Back Access Panel: adım 2, 2 resimden 2.
      • With the laptop facing down, rotate it so the battery pack is facing away from you.
      • Remove the six 1.5 mm Phillips #1 screws on the back panel of the laptop.
      FixBot'a Sor
      Yorum Ekle
    2. Asus F6A-X2 RAM Replacement: adım 3, 3 resimden 1. Asus F6A-X2 RAM Replacement: adım 3, 3 resimden 2. Asus F6A-X2 RAM Replacement: adım 3, 3 resimden 3.
      • Insert a finger into one of the slots on the bottom panel.
      • Gently lift the upwards, and the back panel of the laptop will come off easily.
      FixBot'a Sor
      Yorum Ekle
    1. Asus F6A-X2 RAM Replacement, RAM: adım 4, 2 resimden 1. Asus F6A-X2 RAM Replacement, RAM: adım 4, 2 resimden 2.
      • Make sure to check the RAM specifications on the device page.
      • There are two white plastic tabs holding the RAM in place. Place two fingers on each of these tabs, and pull outward.
      • You will hear a pop and visibly see the RAM move upwards.
      • Slide the RAM towards the back end of the laptop (the end with the battery), and lift up to remove it.
      FixBot'a Sor
      Yorum Ekle
    2. Asus F6A-X2 RAM Replacement: adım 5, 2 resimden 1. Asus F6A-X2 RAM Replacement: adım 5, 2 resimden 2.
      • Repeat the process from the previous step to remove the bottom RAM.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jonathan
1.174 İtibar
11 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-56, Amido Spring 2014 Cal Poly, Team 10-56, Amido Spring 2014 üyesi
CPSU-AMIDO-S14S10G56
4 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
Tutorel simple et très clair.
Merci
alainbadinier - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 8
Son 30 gün: 28
Her zaman: 938
