Ana içeriğe geç
Asus G501JW-BHI7N12 Cooling Fan Replacement
Neye ihtiyacın var
  1. Asus G501JW-BHI7N12 Cooling Fan Replacement, Cooling Fan: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    Satın Al
  2. Asus G501JW-BHI7N12 Cooling Fan Replacement: adım 2, 1 resimden 1.
    • Unscrew and remove the four 5mm Phillips #0 screws from the cooling fan.
  3. Asus G501JW-BHI7N12 Cooling Fan Replacement: adım 3, 1 resimden 1.
    • Remove 4 pin connector from mother board.
  4. Asus G501JW-BHI7N12 Cooling Fan Replacement: adım 4, 1 resimden 1.
    • Slide cooling fan out from underneath the copper heat sink.
    • The cooling fan will be clipped to the case, we suggest pulling it toward the front of the case. Using the spudger can be helpful to work the fan loose.
  5. Asus G501JW-BHI7N12 Cooling Fan Replacement: adım 5, 1 resimden 1.
    • One of the fans will have a connector that partially covers it. Pull the connector loose by flipping up the plastic clamps on both ends and follow steps 2-4.
Sonuç
Dustin Annis
211 İtibar
2 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team 2-1, Rose Winter 2017 UW Tacoma, Team 2-1, Rose Winter 2017 üyesi
UWT-ROSE-W17S2G1
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 27
Her zaman: 2,025
