Ana içeriğe geç
Asus G55VW DS71 Sound Bar Replacement
Neye ihtiyacın var
  1. Asus G55VW DS71 Sound Bar Replacement, Battery: adım 1, 2 resimden 1. Asus G55VW DS71 Sound Bar Replacement, Battery: adım 1, 2 resimden 2.
    • Make sure the computer is off and turn it over on its back. Push the slider all the way back until the compartment for the battery opens. Remove the battery and place it aside.
  2. Asus G55VW DS71 Sound Bar Replacement, Keyboard: adım 2, 2 resimden 1. Asus G55VW DS71 Sound Bar Replacement, Keyboard: adım 2, 2 resimden 2.
    • Find the panel on the back of the computer. Use a Phillips #0 screwdriver to unscrew the 2 4.2mm screws on that panel. Next, lift up the panel at the indent and place it aside.
  3. Asus G55VW DS71 Sound Bar Replacement: adım 3, 1 resimden 1.
    • When the back panel is removed, disconnect the blue and black ribbon connectors exposed from the back panel.
  4. Asus G55VW DS71 Sound Bar Replacement: adım 4, 1 resimden 1.
    • Remove the fifteen 4.2 mm screws on the bottom of the laptop with a Phillips #0 screwdriver, under the battery, and beneath the back panel that secure the keyboard to the laptop.
    • The top-left and upper center screws are difficult to reach with the iFixit screw kit.
  5. Asus G55VW DS71 Sound Bar Replacement: adım 5, 2 resimden 1. Asus G55VW DS71 Sound Bar Replacement: adım 5, 2 resimden 2.
    • Begin to pry the keyboard off of the laptop with the pointed metal spudger.
    • It is possible to damage yourself as well as the device with the metal spudgers. Exercise extreme caution.
  6. Asus G55VW DS71 Sound Bar Replacement: adım 6, 3 resimden 1. Asus G55VW DS71 Sound Bar Replacement: adım 6, 3 resimden 2. Asus G55VW DS71 Sound Bar Replacement: adım 6, 3 resimden 3.
    • Remove the ribbon connectors that connect the keyboard to the motherboard. The keyboard should now be completely disconnected from the laptop.
  7. Asus G55VW DS71 Sound Bar Replacement, Sound Bar: adım 7, 2 resimden 1. Asus G55VW DS71 Sound Bar Replacement, Sound Bar: adım 7, 2 resimden 2.
    • Remove the panel by popping it off.
  8. Asus G55VW DS71 Sound Bar Replacement: adım 8, 2 resimden 1. Asus G55VW DS71 Sound Bar Replacement: adım 8, 2 resimden 2.
    • Use a Phillips #00 screwdriver to unscrew 3 screws on the audio board.
  9. Asus G55VW DS71 Sound Bar Replacement: adım 9, 1 resimden 1.
    • Lift the audio board and find the 2 wires connecting it to the computer.
    • Pull on those wires to disconnect them .
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 224
