Ana içeriğe geç
Asus G73JH-RBBX05 Hard Drive Replacement
Neye ihtiyacın var
  1. Asus G73JH-RBBX05 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Flip the laptop over and remove the two 4mm screws located at the bottom of the laptop with the PH0 screwdriver.
  2. Asus G73JH-RBBX05 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Using a plastic opening tool or finger, remove the access panel.
    • Apply constant force until the panel releases from the clips underneath.
  3. Asus G73JH-RBBX05 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Locate the two, 4mm screws on the hard drive. Remove them with the PH0 screwdriver.
  4. Asus G73JH-RBBX05 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Using the black tab located on the hard drive, pull out the hard drive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Trevor Sprosty
409 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-11, Maness Winter 2017 Cal Poly, Team 22-11, Maness Winter 2017 üyesi
CPSU-MANESS-W17S22G11
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 16
Her zaman: 764
