Ana içeriğe geç
Asus G73JW-XT1 Hard Drive Replacement
Neye ihtiyacın var
  1. Asus G73JW-XT1 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Flip the device over so the battery port is easy to access.
  2. Asus G73JW-XT1 Hard Drive Replacement: adım 2, 2 resimden 1. Asus G73JW-XT1 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Slide the left slider to the left so that it locks in place.
    • Slide the right slider to the right while pushing the battery away from you. The battery should disconnect.
  3. Asus G73JW-XT1 Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 1. Asus G73JW-XT1 Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 2. Asus G73JW-XT1 Hard Drive Replacement, Hard Drive: adım 3, 3 resimden 3.
    • Remove the two 5.5 mm Phillips #0 screws from the back cover.
    • Gently lift and remove the back cover.
  4. Asus G73JW-XT1 Hard Drive Replacement: adım 4, 3 resimden 1. Asus G73JW-XT1 Hard Drive Replacement: adım 4, 3 resimden 2. Asus G73JW-XT1 Hard Drive Replacement: adım 4, 3 resimden 3.
    • Remove the four 5.5 mm Phillips #0 screws.
    • Gently lift the hard drive starting on the far side.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 216
