Ana içeriğe geç
Asus G74SX-BBK7 Hard Drive Replacement
Neye ihtiyacın var
  1. Asus G74SX-BBK7 Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the large screw on the bottom of the laptop.
    • After the screw is removed, take off the back panel.
  2. Asus G74SX-BBK7 Hard Drive Replacement: adım 2, 2 resimden 1. Asus G74SX-BBK7 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Locate the hard drive in the lower left corner.
    • Unscrew four 6mm Phillip #0 screws from the hard drive mounting.
  3. Asus G74SX-BBK7 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Unplug and remove the hard drive by pulling up on the black tab on top of the hard drive.
    • A spudger may assist in prying up the black tab.
  4. Asus G74SX-BBK7 Hard Drive Replacement: adım 4, 2 resimden 1. Asus G74SX-BBK7 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Unscrew two 3mm Phillips #0 screws to remove the casing on the hard drive.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ryan Lawrence
611 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-10, Maness Spring 2015 Cal Poly, Team 5-10, Maness Spring 2015 üyesi
CPSU-MANESS-S15S5G10
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 30
Her zaman: 3,283
