Ana içeriğe geç
Asus G74SX-BBK7 RAM Replacement
Neye ihtiyacın var
  1. Asus G74SX-BBK7 RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the large 13mm screw on the bottom of the laptop.
    • Take off the back panel.
  2. Asus G74SX-BBK7 RAM Replacement: adım 2, 3 resimden 1. Asus G74SX-BBK7 RAM Replacement: adım 2, 3 resimden 2. Asus G74SX-BBK7 RAM Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Locate the RAM near the center of the computer.
    • Push gently on the metal pins that are on both sides of the RAM sticks.
    • Before touching the RAM, discharge any built-up static by touching a metal surface or wearing an antistatic wrist strap.
  3. Asus G74SX-BBK7 RAM Replacement: adım 3, 1 resimden 1.
    • When you push on the pins, the RAM will pop up. Gently remove it from its socket.
    • Repeat the third and fourth step for the second stick of RAM, located behind the first stick.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Josiah Avery
131 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 5-10, Maness Spring 2015 Cal Poly, Team 5-10, Maness Spring 2015 üyesi
CPSU-MANESS-S15S5G10
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 977
