Ana içeriğe geç
Asus G74SX-BBK7 Trackpad Button Replacement
Neye ihtiyacın var
  1. Asus G74SX-BBK7 Trackpad Button Replacement, Optical Drive: adım 1, 1 resimden 1.
    • Using a flathead screwdriver, spudger, or large coin such as a quarter, remove the 13mm screw on the bottom of the laptop.
    • Take off the back panel.
  2. Asus G74SX-BBK7 Trackpad Button Replacement: adım 2, 1 resimden 1.
    • Now, unscrew and remove the 6mm Phillips #0 screw next to the optical drive.
  3. Asus G74SX-BBK7 Trackpad Button Replacement: adım 3, 2 resimden 1. Asus G74SX-BBK7 Trackpad Button Replacement: adım 3, 2 resimden 2.
    • Lastly, use a plastic opening tool to remove the optical drive from its slot.
  4. Asus G74SX-BBK7 Trackpad Button Replacement, Trackpad Button: adım 4, 1 resimden 1.
    • Remove the two 6mm Phillips #0 screws that were previously covered by the optical drive using a Phillips #0 screwdriver.
  5. Asus G74SX-BBK7 Trackpad Button Replacement: adım 5, 1 resimden 1.
    • First, remove the five 10mm Phillips #0 screws from the back of the computer near the top.
    • Remove all eighteen 6mm Phillips #0 screws from the bottom of the computer.
    • Some of the screws are set very deeply in the back case - you will need a long and narrow screwdriver to remove them.
  6. Asus G74SX-BBK7 Trackpad Button Replacement: adım 6, 2 resimden 1. Asus G74SX-BBK7 Trackpad Button Replacement: adım 6, 2 resimden 2.
    • Next, pry open back plastic cover using a metal spudger.
    • Unscrew the four 10mm Phillips #0 screws under the cover.
  7. Asus G74SX-BBK7 Trackpad Button Replacement: adım 7, 3 resimden 1. Asus G74SX-BBK7 Trackpad Button Replacement: adım 7, 3 resimden 2. Asus G74SX-BBK7 Trackpad Button Replacement: adım 7, 3 resimden 3.
    • Lay laptop opened and completely flat.
    • Using the metal spudger, slowly pry open the front main panel by going around each side.
    • Lift the top panel out, pulling the cable strips out of their sockets. These will be reattached later.
    • Be careful when lifting the top panel. There are cable strips attached to the motherboard that need to be removed.
  8. Asus G74SX-BBK7 Trackpad Button Replacement: adım 8, 2 resimden 1. Asus G74SX-BBK7 Trackpad Button Replacement: adım 8, 2 resimden 2.
    • After separating the main panel and the motherboard, unscrew two 6mm Phillips #0 screws.
    • Remove the mouse button.
  9. Asus G74SX-BBK7 Trackpad Button Replacement: adım 9, 3 resimden 1. Asus G74SX-BBK7 Trackpad Button Replacement: adım 9, 3 resimden 2. Asus G74SX-BBK7 Trackpad Button Replacement: adım 9, 3 resimden 3.
    • To reconnect the motherboard and main panel, insert strips back to their corresponding location.
    • To do this, first remove the tape and open up the tab. Plug in the strip and and close the tab.
    • It may be helpful to have someone help you hold the main panel while you reconnect the strips.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ryan Lawrence
611 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-10, Maness Spring 2015 Cal Poly, Team 5-10, Maness Spring 2015 üyesi
CPSU-MANESS-S15S5G10
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Where did you find the part?
websmiths - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 4,773
