Ana içeriğe geç
Asus G750JW-BBI7N05 RAM Replacement
Neye ihtiyacın var
  1. Asus G750JW-BBI7N05 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Power off and unplug your laptop, then turn it over.
  2. Asus G750JW-BBI7N05 RAM Replacement: adım 2, 1 resimden 1.
    • Slide the battery release latch all the way to the right. This will cause the battery to "pop" out slightly.
  3. Asus G750JW-BBI7N05 RAM Replacement: adım 3, 1 resimden 1.
    • Remove the battery from its compartment.
  4. Asus G750JW-BBI7N05 RAM Replacement, RAM: adım 4, 2 resimden 1. Asus G750JW-BBI7N05 RAM Replacement, RAM: adım 4, 2 resimden 2.
    • Lift up the rubber stopper on the backplate to expose one Phillips screw. Unscrew it until it becomes loose.
    • This screw is permanently connected to the backplate and cannot be removed. Unscrewing it only allows you to remove the backplate from the laptop.
    • The backpate is the plastic plate on the underside of the laptop that covers some of its easily accessible internal components.
  5. Asus G750JW-BBI7N05 RAM Replacement: adım 5, 1 resimden 1.
    • Use an opening tool to pry up the backplate along its edges, then remove it.
    • You may need to apply some force when prying up the backplate.
    • Keep in mind: During reassembly, replace the backplate starting from the bottom.
  6. Asus G750JW-BBI7N05 RAM Replacement: adım 6, 2 resimden 1. Asus G750JW-BBI7N05 RAM Replacement: adım 6, 2 resimden 2.
    • During the recycling process, this laptop lost some of its parts. In this step, its top two RAM modules are missing.
    • Remove each RAM module one at a time by sliding them downward out of their slots.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
What about how to remove the other two internal RAM Modules?
Latiron London - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 761
