Giriş
The Audio Jack can wear out over time or stop working completely. This guide will show you how to remove the Audio Jack on the side of the device.
Neye ihtiyacın var
Remove the 5 (9 mm screws) around the outside edges of the back cover with the PH1 Phillips-head screwdriver.
Lift off the back cover using the opening tool.
Bir başkası bu kılavuzu tamamladı.
