Ana içeriğe geç
Asus G75VW-BHI7N07 Audio Jack Replacement
Neye ihtiyacın var
  1. Asus G75VW-BHI7N07 Audio Jack  Replacement, Audio Jack: adım 1, 3 resimden 1. Asus G75VW-BHI7N07 Audio Jack  Replacement, Audio Jack: adım 1, 3 resimden 2. Asus G75VW-BHI7N07 Audio Jack  Replacement, Audio Jack: adım 1, 3 resimden 3.
    • Remove the 5 (9 mm screws) around the outside edges of the back cover with the PH1 Phillips-head screwdriver.
    • Lift off the back cover using the opening tool.
  2. Asus G75VW-BHI7N07 Audio Jack  Replacement: adım 2, 3 resimden 1. Asus G75VW-BHI7N07 Audio Jack  Replacement: adım 2, 3 resimden 2. Asus G75VW-BHI7N07 Audio Jack  Replacement: adım 2, 3 resimden 3.
    • Remove the 10 (9 mm) screws marked 'A' using the PH1 Phillips-head screwdriver.
    • Remove the battery by pressing the slide release button.
    • Remove 2 more (9 mm) 'A' marked screws within the battery compartment using the PH1 Phillips-head screwdriver.
  3. Asus G75VW-BHI7N07 Audio Jack  Replacement: adım 3, 2 resimden 1. Asus G75VW-BHI7N07 Audio Jack  Replacement: adım 3, 2 resimden 2.
    • Remove the cover for the disc drive with the opening tool.
    • Remove the 6 (4 mm) 'B' marked screws with the PH1 Phillips-head screwdriver. (3 screws are in the battery compartment and 3 are under the disc drive cover)
  4. Asus G75VW-BHI7N07 Audio Jack  Replacement: adım 4, 2 resimden 1. Asus G75VW-BHI7N07 Audio Jack  Replacement: adım 4, 2 resimden 2.
    • Pry open the keypad platform with the opening tool.
    • You will need to lift the keypad platform with your hands to get to the laptop's internal systems.
  5. Asus G75VW-BHI7N07 Audio Jack  Replacement: adım 5, 3 resimden 1. Asus G75VW-BHI7N07 Audio Jack  Replacement: adım 5, 3 resimden 2. Asus G75VW-BHI7N07 Audio Jack  Replacement: adım 5, 3 resimden 3.
    • Take out 1 (5mm) screw, using the J0 Phillips head screwdriver.
    • Use the opening tool to remove the audio-electrical board.
    • Lift out with your hands.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joy
437 İtibar
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 650
